Old 04-30-2014, 03:34 PM   #1
Chair Rail Dilemma
Yesterday, I was removing all of the rivets off the interior side walls of my Bluebird bus. I got EVERY rivet removed. I did not realize that the lower panel, with the chair rail, was constructed the way it was until today, when Nat_ster told me about it and showed his diagram:
The problem is... in my rivet-removing haste, I ALREADY removed all of these rivets holding the chair rail in. Not only that, but I hacked a big section out trying to figure out what was holding it in. You can see the rail I am talking about here (NOTE This is not my bus, it is LaCasitaBus):
I have done a lot of research and many said to not remove it. I was feeling sick to my stomach that I took two steps forward and a MAJOR step back until I found this (The Good Ship, Anne Marie):
In their page, they detailed the same sort of dilemma at this page:
viewtopic.php?f=9&t=392717&hilit=the+good+ship+ann e+marie&start=30
That made me feel a bit better that I wasn't the only one who made this mistake. So... I know our buses are way overbuilt. What is going to happen if I continue with the removal of this chair rail? Is it going to cause some serious problems or will it likely never show in an RV application? Will my floors somehow separate from my walls or will I be just fine? The rivet's are 1/4" and will offer a pretty significant expense to re-rivet all of them, including investing in necessary tooling. Should I just continue and cut them out with an angle grinder?
I could really use some advice right now and I think this thread could be a good example for others in the future of what to do (or what NOT to do) with the chair rails. As it sits, I have spent hours reading posts and researching today, only to come up with no conclusive evidence on whether or not it will be harmful to remove them. Thoughts?
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 04-30-2014, 06:14 PM   #2
Re: Chair Rail Dilemma
if it work ok with there build, then It should be ok with your build
Old 04-30-2014, 06:38 PM   #3
Do we really know if it worked OK?!? They aren't done with it yet Has anyone else cut this out?
WVO Powered!
Old 04-30-2014, 10:31 PM   #4
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
I looked into what it would take to tear the chair rail out of my Thomas and decided to leave it and use it as an attachment point for the cabinetry and bunks. It looked to be a MAJOR project to remove it and I just plain ol' don't want to put that much work into this thing for as much as it'll be used.
Riviting tools are not inexpensive if you get quality stuff but they you have it and can use it for a million other things in the future. I have no problem buying a tool that'll save me time or even a few bucks if I can use it again in the future.
Passes everything but gas stations.
bamper is offline   Reply With Quote
Old 04-30-2014, 10:37 PM   #5
I do still have to rivet the window skins on when the time comes, so I can see this as an advantage. However, this doesn't help the fact that I already hacked into a chunk of the wall too I made about a 2.5 foot cut into the chair rail panel near the back of the bus to try to see if I could break it free. My mindset at the time was that it all had to come out. I was out in the boonies at a friends house, with no internet access, so I just had to go with memory. If I could remove the chair rail and the bus survive, I think this would be my preferred route.
But... then there's that whole structural integrity thing
WVO Powered!
Old 05-02-2014, 05:47 AM   #6
Yesterday I finished removing the ceiling panels and while I was out there I realized it wasn't as big of a task to re-rivet as I was thinking. Anyone have a source of some quality affordable steel rivets? Everything I find is stainless or aluminum. I don't want to have any corrosion from dissimilar metals.
The "hack" in the wall is just a single long cut. I figured I could cut two patches of the ceiling panels that we will not be reusing, place one on each side of the wall, and rivet in!
I am debating buying an air rivet gun that I found posted before. It's a good price with all the heads, bucking bars, etc. I have to rivet the outside window skins anyways. I figured we could sell it when we are done to recoup some investment (since we will be full timing I. The bus with limited space and tool capacity).
I've never riveted a single thing in my life, but am willing to learn!
Question though... If I were to use a rivet gun to reattach the chair rails, how would that happen? There is no space to get a bucking bar in. Is there a special type of rivet for this? Excuse my ignorance!
WVO Powered!
Old 05-02-2014, 11:03 PM   #7
Nat_ster... Would these be the rivets I need?
http://www.amazon.com/gp/aw/d/B00AGLOMQ ... mdsc?dsc=1
Or these?
http://www.amazon.com/gp/aw/d/B00FAUEVU ... SY165_QL70
WVO Powered!
Old 07-24-2018, 01:24 AM   #8
CMAK17's Avatar
Coachwork: Champion
Chassis: Chevy P6500
Engine: GM tbi 427T 7.0L
Rivets are funny things. You're going to need to actually measure each hole and order accordingly. SS is your best bet and strongest rivet.
CMAK17 is offline   Reply With Quote
Old 07-28-2018, 04:52 PM   #9
golfersmurf57's Avatar
You can use an air riveted, but if its old school buck rivets, you're gonna be holding and bucking for hours. In going pop rivets paintable and if you need a stronger grip, there's backup washers available. I bought a 5 lbs. box at fastenal for $65 and rivet tool was $15 at harbor freight. If I wear it out. Another $15 is still cheap. I have a BLUEBIRD too. Was wondering about the seat rail too. If it's that much trouble, I will fire up the zizz wheel and cut it flush with the wall then grind it smooth. I'm removing the center window frames before skinning over them using the original mounting holes and 16 gauge sheet metal will add bracing if the wind makes them vibrate during travel.
golfersmurf57 is offline   Reply With Quote
Old 07-28-2018, 05:12 PM   #10
You'd be making a huge mistake cutting your chair rail. It is a structural part of the bus helping to keep it from bowing up and down. If you zip wheel the chair lip you will now have a piece on the face and a separate piece on top and will have removed the most structural part of the rail.
Old 07-28-2018, 07:56 PM   #11
CMAK17's Avatar
Coachwork: Champion
:dange r:
Old 07-29-2018, 03:49 PM   #12
I am afraid that it may be too late......
Looks like the OP removed his chair rail four years ago......
PNW_Steve is online now   Reply With Quote
Old 07-29-2018, 04:31 PM   #13
And hasn't been back since. Golfersmurf is considering cutting his out even though no one has said it was good idea, in fact recommending the exact opposite. I didn't realize the OP was 4 years old.
Old 07-30-2018, 06:13 PM   #14
Well it's sticking out ..... O
k ok I haven't yet !if I remove it what if I rivet back on a flat strip of aluminum? Does it need the angled structure for stability? Cause that's a full inch on each side. I can see the vertical adding strength but I'd think the framework of the bus would be better built to withstand it.
Old 07-30-2018, 06:46 PM   #15
The bus is better built to withstand it because of the chair rail. I would not replace it with a flat strip of aluminum and expect the same results.
Old 07-30-2018, 07:18 PM   #16
Ok but hope I can slit the insulation enough to lay flat
Old 07-31-2018, 12:04 AM   #17
CMAK17's Avatar
Coachwork: Champion
Mine is 10" off the floor and has holes every 1.5" or so. I like it and plan to keep it accessible as an anchor point for various things... even ratchet straps and bungie cords. I also plan to install logistic rails in a few places to use as anchor points for temporary/moveable walls, decking bars, etc...
A minor bus dilemma baadpuppy Everything Else | General Skoolie Discussions 13 07-28-2015 08:58 AM
Chair Rail On A Crown Stu & Filo. T Conversion General Discussions 4 10-23-2013 09:35 PM
Bunk bed dilemma Diesel Dan Conversion General Discussions 12 10-27-2009 09:03 PM
The chair rail - what did you make of it? Elliot Naess Conversion General Discussions 5 01-13-2008 05:03 PM
Captains Chair (drivers seat) dogfinn Skoolie Conversion Projects 9 12-31-1969 07:00 PM
