Old 07-14-2019, 01:45 PM   #1
Coachwork: Thomas MVP
Chassis: Thomas MVP
Engine: Cummins 5.9 250HP w/ Allison MD3060
Chair rail insulation
Hey Iíve been looking through threads all morning and canít find an answer. Has anyone successfully been able to get 2Ē XPS foam board stuffed into the cavity behind chair rail? Iím not really sure what to do if I canít get it to fit. Iím doing 2 inch floor insulation and 4 inch total for walls and ceiling anyways thanks for your time
Olympia_Lowlife is offline   Reply With Quote
Old 07-14-2019, 02:02 PM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
What's your space constraint behind the rail?
Might do well to put multiple plys of 1/2" board.
(It will be very helpful if you populate the fields in your profile, so we all know what sort of bus you're working with...)
Old 07-14-2019, 04:00 PM   #3
Chassis: Thomas MVP
Hey I went and updated my profile but it is a 2002 Thomas MVP 84 passenger and I think the space was just shy of 2 inches I didn’t know if people liked to shave down 2 inch a bit or put smaller and spray foam around it or something
Old 07-14-2019, 04:33 PM   #4
2" won't fit in the cavity. I use 1/2" piece of Polyiso, foil outside, and then back that with 1" rigid pink.
o1marc is online now   Reply With Quote
Old 07-14-2019, 05:18 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
Have a look down the slot to see why the board won't go in. Are there rivets or other features blocking the way? Is the board simply too thick?
Pourable foam is an option you might consider.
Old 07-14-2019, 07:19 PM   #6
The hat channels are only 1-1/2" , 2" will not fit.
