Old 10-20-2013, 12:43 PM   #1
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Chair Rail On A Crown
Has anyone removed the chair rail on a Crown Bus? How important is it to structural integrity ?
Old 10-21-2013, 01:09 PM   #2
usmcbay's Avatar
Coachwork: Thomas MVP
Chassis: Saf-T-Liner ER
Re: Chair Rail On A Crown
From what I've read on here its not worth the work and problems it creates... I did see a Tailgating bus they put a rather thick sheet of Aluminum over the Rub Rails and then put a Vinyl Wrap banner on it... it looked good!
Here's my Bus Conversion...
viewtopic.php?f=11&t=12202
usmcbay is offline   Reply With Quote
Old 10-21-2013, 01:44 PM   #3
Did you mean to address Rub Rails or Chair Rails? I'm talking about the rail on the inside where the seats bolt to the wall, its welded to the inside of the ribs & I'm wondering if it's for added strength or just to support the chairs,If I can remove it I gain about 3 in in with I can use
Old 10-21-2013, 02:07 PM   #4
A lot of folks use that area as wire/plumbing "chases" to hide every thing behind a base board
Old 10-23-2013, 08:35 PM   #5
Coachwork: Corbeil
Engine: T444e
I cut off approx. 3" to remove the part the chair sits on. Do not completely remove it though, it is what attaches the posts to the floor. It is structural.
Alex and Angie is offline   Reply With Quote
Chair Rail Dilemma White99z Conversion General Discussions 16 07-30-2018 11:04 PM
Wanted: Wheel chair tie-downs skooliegoober Classifieds | Buy, Sell, Swap 5 12-30-2012 04:34 AM
Captains Chair (drivers seat) dogfinn Conversion General Discussions 7 10-12-2012 05:26 PM
The chair rail - what did you make of it? Elliot Naess Conversion General Discussions 5 01-13-2008 04:03 PM
Captains Chair (drivers seat) dogfinn Skoolie Conversion Projects 9 12-31-1969 07:00 PM
