Re: Charging multiple battery banks
I have run isolators before and they are relatively easy to install. Surpower is prolly the most common. Their website will have some diagrams.
Determine if there is some sort of diode that prevents current flowing to your alternator if you are charging via shore power or generator. I am sure there is but make sure. Wouldnt want to smoke your alternator. You will need to know the amperage and manufacture of your alternator, ie 130amp/delco and/or internal regulator etc. Whoever you source it from should help you.
