Old 07-29-2010, 10:42 PM   #1
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Charging Troubles
Ah, how many amps does your battery charger put out. My Battery Minder is 8 amps, max. Not much, and would take a long time to charge. You've got to figure how much you're taking out, as opposed to how much you're putting in--over time.
Don't know if this affects you, but some chargers won't really work when run from cheap generators.
Old 08-05-2010, 08:55 PM   #2
bus-bro's Avatar
Remember that in converting your 120 volt AC watts to 12 volt DC amps you divide your power (watts) by 12 (more like 12.5 to 14 volts). 96 watts equals 8 amps at 12 volts. So that 96 watt load will be more (with the power losses) than your 8 amp charger puts out. 8 amps x14 volts(charger output) =112 watts x 0.7(off the cuff efficency factor) =78 watts available to your AC loads.
Battery charging question Diesel Dan Electrical, Charging and Solar 1 04-29-2011 03:47 PM
Bus Conversion Insurance Troubles in MA the_experience03 Titles, Insurance, Registration and Money Matters 1 11-02-2009 09:11 PM
starting troubles when coming home today. Train-train Conversion General Discussions 3 10-15-2007 10:54 AM
Shower troubles! KC10Chief Conversion General Discussions 5 07-27-2007 11:20 AM
Inverter troubles frey2 Conversion General Discussions 6 05-15-2005 01:07 PM
