Old 05-26-2004, 01:23 PM   #1
Steve's Avatar
Cheap Backup Camera
My camera came in today and it is much smaller than I had expected it.
I ordered the X10 Anaconda that comes with a 60FT phone cord type cable that is small and easy to route up to the front. They also have a black and white version that should work better in low light conditions.
Within a minute of unpacking it I had it connected to a TV and working for a little test.
Time to get back to work, I'll get back to this project tonight.
Here is an article from some using the same camera on thier van.
http://www.funddealernet.com/cartercam/cartercambw.asp
Old 05-26-2004, 10:25 PM   #2
Steve's Avatar
adamb came over and helped me get the camera hooked up and run through the bus. Here is a pic of it mounted on the back, you can really see how small it is here.
Soon I will mount the LCD screen and connect the TV and camera up to a switch.
Old 05-27-2004, 06:20 AM   #3
Vern1's Avatar
Engine: 345 IH gas
Rated Cap: 66 passenger
Greetings,
I have been using the X10 cameras at my paintball field for security.
I have 3 of the black and white low light ones in the staging area where the folks keep their stuff while playing.
Theft has dropped to almost zero!
I have the same color camera setup you have mounted on the bus and hooked into the TV with a video switch.
It's cool that you have sound too!
When I use mine, it is projected on the TV behind me.
I use the interior mirror to check the TV while I watch the rear view mirrors on the outside while backing up.
It helps quite a bit.
Also later, when I start using a toad, I can check up on it every once in a while.
FYI, I have had the color one for about two years and used it for everything you can imagine - well, maybe not - then put it in the bus.
If you look on page 6 of my web, on the picture of the rear of the bus, you can see the little X10 sitting on the top right where the flashers used to be. It even has it's own little "awning" made out of aluminum.
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
https://www.pettypb.com/bus
Vern1 is offline   Reply With Quote
Old 05-27-2004, 12:42 PM   #4
Steve's Avatar
Here is the LCD screen mounted next to the rear view mirror. A single small cord runs above the windshield and is not noticable.
Old 05-27-2004, 12:58 PM   #5
Steve's Avatar
Here is a schematic showing how it works.
Old 06-01-2004, 01:37 PM   #6
Steve's Avatar
What made you decide to put it off to the side instead of in the middle?
Old 06-02-2004, 06:07 AM   #7
Vern1's Avatar
Engine: 345 IH gas
Greetings,
The one I have is one of the early X10s and only had 20' of cable.
I knew where the TV was going to be and started there with the cable and ended up on the side.
It was also easy to mount and wire it there as I had the blanking panel for the emergency lights and that ment easy access later if I have problems.
Also, early on, I was planning on putting some lettering in the center panel where it used to say "SCHOOL BUS"..........
Cheers,
Vern1
Old 07-29-2004, 03:29 PM   #8
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
Another Camera Source
Here is another source for an affordable camera (a little less than the X10 camera). Go to http://www.harborfreight.com and search for camera. They have a $30 black and white night vision camera and a $40 color camera. Both come with 80ft of wiring. So far I've got an 4" LCD off ebay, I just need to order a camera. Since I do not own one of these camearas yet I do not know how good they are (but I am a regular Harbor Freight customer).
Chad
http://trx.punknet.org/geeklog/public_h ... Conversion
trx is offline   Reply With Quote
Old 03-01-2005, 11:15 AM   #9
Send a message via Yahoo to TravelingMan
I just wanted to add another option. I just bought a small wirless color by day/infrared led black and white at nite survalince camera thats water-proof with built in transmiter and a remote tunable receiver, both can be run off batteries or with the supplied AC adapters off ebay for $54. I don't think it would do well in a bus but they also have a wired version of this camera that I think may even cost a little less.
"I'm a man of means by no means King of the road"
TravelingMan is offline   Reply With Quote
Old 03-02-2005, 06:09 PM   #10
Foggy Dewhurst's Avatar
Location: Texas, Formally Radcliffe, (Cotton Mill Contry) Near Manchester Limey Land
Coachwork: Bluebird - Shorty
Engine: International 7.2 V 8
Steve,
Where did you get your LCD moniter
Looks like just the right size for the job.
Thanks, Barrie
Foggy
1989 GMC Vandura 19 Passenger,
With a 6.2 Diesel Motor
Member # 25
Foggy Dewhurst is offline   Reply With Quote
Old 03-02-2005, 06:53 PM   #11
Steve's Avatar
The monitor shown here [click for larger view] is from Radio Shack. This one is one of the waterproof models not sure they still make it anymore.
Old 03-03-2005, 08:08 AM   #12
trx
trx's Avatar
Chassis: Chevy C-60
Does it show a mirror image so it works like a rear view mirror? If not, how hard is it to use when backing up? I've got a 4" LCD I got off ebay awhile back but it doesn't show a mirror image. I think Parts Express had an LCD monitor that could display a mirror image (I can't get to their site right now to check).
Old 03-03-2005, 09:41 PM   #13
frey2's Avatar
harbor frieght sells a littel security camera no bigger that a pc camera for $25 that comes with an 80' cord with video sound power all bundled together. even has a little night vision deal.
i got one to go on the back of the bus and one to go on the back of the trailer.
Nicholas Frey
Transportation Chairman
Society of Automotive Engineers
University of South Florida
The first requisite of a good citizen in this republic of ours is that he shall be able and willing to pull his own weight.
-Theodore Roosevelt
frey2 is offline   Reply With Quote
Old 03-04-2005, 07:19 AM   #14
Send a message via Yahoo to capttrips25
you stold my idea!
I bought 2 of those from 10X and have been planning on doing exactly that with one of them.
I have a small "Watchman" type tv that I was going to use with it.
Sans Puer!!!
capttrips25 is offline   Reply With Quote
Old 04-05-2005, 08:47 AM   #15
trx
trx's Avatar
Chassis: Chevy C-60
I just purchased this camera for my bus: http://www.ewis.ca/onlinestore/scrip...idproduct=1077
What I liked about this camera is the 2-way intercom. Nice to be able to communicate with someone helping you back up (or to tell people to get out of the way!). Just got it yesterday and seems to work fine.
Chad
http://trx.punknet.org/geeklog/publi...olieConversion
Old 04-06-2005, 09:53 PM   #16
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
Any progress on the hauler trx or have you been snowed in like me?
Firearm is offline   Reply With Quote
Old 04-07-2005, 07:46 AM   #17
trx
trx's Avatar
Chassis: Chevy C-60
No progress over the winter months (excuse to take a break). Just starting on it again now.
Backup beeper - keep it or trash it? roach711 Conversion General Discussions 13 11-04-2015 02:30 PM
BB Bus for cheap frank-id Classifieds | Buy, Sell, Swap 0 08-09-2014 11:17 AM
bus back up camera keith Classifieds | Buy, Sell, Swap 7 05-07-2012 10:28 AM
Backup Camera? hoser Conversion General Discussions 4 10-25-2009 05:10 AM
Backup 12v Air Compressor 1964_Superior_Skoolie Conversion General Discussions 14 12-21-2006 09:58 PM
