Old 03-08-2006, 05:48 PM   #11
phillbus914's Avatar
I hooked mine up & it works fine, so I'm not worried about the physical damage.
My Old Bus :(
Old 03-10-2006, 07:18 PM   #12
inverters
Thanks for the line. I've oredered one too. Should be here Mon. Cant wait to get started on my wiring. Will begin that Sunday. Going to run a 220 plug to 4- 20amp breakers. From there to four duplex outlets. From the outlets, 2 are going to 10 gauge extension cords for the AC, and my Ref/Microwave. The other 2 are going to power the lights on either side of the bus. 12 Gauge cords will be used for these. I'm also planning to build a rear deck which will house a 3500W generator. The plan is to use the 220 plug whenever at an rv friendly camp. When dry camping or running down the road, I'll unplug the 2 appliance cords from their outlets and run them to a dedicated line running to the generator. the other 2 lines (for the lights, etc.) will go to my inverter, which I'll have attached to 2 100AH marine batteries. Should work for me well enough. Look forward to getting started. Will post pix as able. GBYA
majjecc is offline   Reply With Quote
Power inverters and electrical questions MissJaneStrummor Conversion Tutorials and How-to's 1 04-16-2014 01:34 PM
Power inverters and their uses drchefscott Skoolie Conversion Projects 17 04-16-2009 08:46 AM
Harbor freight power inverters lapeer20m Conversion General Discussions 0 09-20-2007 10:15 PM
cheap power inverters batchlor BusMan Everything Else | General Skoolie Discussions 2 04-06-2004 05:02 PM
Power Inverters - which makes more sense? bus.driver Everything Else | General Skoolie Discussions 2 02-24-2004 11:01 AM
