Old 02-14-2017, 09:56 PM   #1
spenceronehalf's Avatar
Coachwork: Never coached any teams, not even junior soccer
Chassis: I'm still figuring out what this means
Engine: CAT diesel
Rated Cap: No caps, only hats.
Chicken or Egg?
DMV says I need my bus there to get my class C license. But I need my class C license to legally drive to the DMV. Ideas?
Sent from my iPad using Tapatalk
spenceronehalf is offline   Reply With Quote
Old 02-15-2017, 12:44 AM   #2
I guess you have to find someone else with a license to drive you there - just like a kid getting that first driver's license had to have a parent or older friend lend a hand/car.
Sent from my Ascend Mate 2 using Tapatalk
lucasd is offline   Reply With Quote
Old 02-15-2017, 12:57 AM   #3
If your bus is registered and titled as an RV all you should need is a regular driver's license.
I know there are some jurisdictions that require a different regular license to drive RV's over a certain size. If that is the case with you, make sure the seats are out and anything having to do with a school bus (stop paddle, crossing arm, 8-way lights, School Bus id, etc.) need to be removed and or disabled. The less your school bus looks like a school bus the better it will be for you.
Old 02-15-2017, 06:19 AM   #4
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Yep in illinois, although I thought that big bus you got would weigh in for a class B like mine.
You just need to get someone with the right license to get it to the dmv for you.
You are licensed by weight here CDL or not.
Sent from my SM-G920V using Tapatalk
wunderhut is offline   Reply With Quote
Old 02-15-2017, 06:59 AM   #5
Engine: CAT diesel
The bus manual I found online says 36k lbs. that's what puts us up into class c. Will find a buddy
Old 02-15-2017, 07:23 AM   #6
jctrembly's Avatar
Chassis: Amtram RE
Engine: 466 250hp HT
Without looking it up, what is required "in" state (intrastate) is not the same as what's required if you drive "out" (interstate) of state: ie: crossing a state line.
Anything vehicle with 16 occupants + (driver included) and traveling across state lines requires a Class B CDL per Federal regulations. Weight doesn't matter. Nor does how many seats the vehicle has, it is based on manufacturer design, even if all the seats are gone. I live 8 miles from a state line and we do 80% of most everything in that state. It kinda sucks but crossing a state line really complicates many things.
The only way around the CDL is to only drive IN state untill you re-title the bus as a motorhome.
http://www.streetdirectory.com/trave...eed_a_cdl.html
Sent from my Nexus 5X using Tapatalk
jctrembly is offline   Reply With Quote
Old 02-15-2017, 07:31 AM   #7
Engine: CAT diesel
SUPER complicated
I wish I didn't find this licensing part of things so complicated! But I think I get it now: since my bus is already classified as an RV, it sounds like I'll need a Class B (due to weight). At least that's how it sounds now ...
Big thanks!
Old 02-15-2017, 07:44 AM   #8
jctrembly's Avatar
Chassis: Amtram RE
Nope, motorhomes are exempt air brakes or not. Again, I haven't looked up your state laws but motorhomes are motorhomes not trucks or buses.
If one state requires anything but a regular drivers license for a motorhome they would be able to ticket most any out of state large motorhome driver.
Old 02-15-2017, 09:38 AM   #9
Engine: CAT diesel
Getting Clearer
Okay, so you're saying that since my bus is legally a motorhome but has air brakes then I need the CDL. I think I get that.
Old 02-15-2017, 10:15 AM   #10
Never heard of a CDL req for air brakes on an RV in the US. Canada...oui. US ???
