Old 02-16-2010, 05:10 AM   #1
busdriver_phil's Avatar
Coachwork: AmTran RE
Re: Clearance lighting
They're required by federal law, FMVSS 108.
http://www.ntea.com/uploadedFiles/NTEA_ ... _chart.pdf
Basically, you should put the lights back where they were. 3 in the center of the roof cap front and rear (6-12" spacing), one at each top corner, and one halfway down the length of the bus on each side (line up with the reflector at the bottom). Front and middle should be amber, rear should be red.
The conversion of Miss Euphegenia, a 1999 AmTran RE: http://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Old 02-16-2010, 09:12 AM   #2
check with the stste police on the 3 center id lights, since you're noncommercial rv,they might not be necessary. If you don't have to have them I wouldn.t put them on, reason being if you have them they have to work, if they arent there it's one less thing that you can be stopped for.
Old 02-16-2010, 10:38 AM   #3
The state police might not know, it's a federal requirement. Then again, state police don't always know state laws either.
That link I posted says the center ID lights are required for all vehicles over 80" wide. It doesn't say anything about commercial or non-commercial. Dually pickups have ID lights, even if they're registered with passenger plates. Basically, the lights warn other drivers at night that you're big.
And Smitty, your bus had the lights, the ID lights are the 3 on the top edge of the roof cap, over the "SCHOOL BUS" sign.
All 12VDC for lighting rex_1_mn Electrical, Charging and Solar 20 03-03-2016 07:19 AM
clearance/understorage/floor space/traveling lornaschinske Conversion General Discussions 6 05-14-2010 01:15 AM
Wood stove pipe clearance to wall. arfisher83 Everything Else | General Skoolie Discussions 7 11-01-2009 09:44 PM
Head room and ground clearance 3toedgecko Conversion General Discussions 5 12-21-2006 11:41 PM
LED Lighting questions captainkf Conversion General Discussions 4 03-15-2005 08:10 PM
