Old 11-12-2015, 02:45 PM   #11
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Originally Posted by nat_ster View Post
If I installed that window with silicone, and proper surface prep, you would never get the window out of the opening ever again.
That said, the next person who has to take that window out to fix a broken pane or recaulk is gonna hate your guts
Puggy is offline   Reply With Quote
Old 11-12-2015, 02:53 PM   #12
Chassis: B3800 Short bus
Originally Posted by Puggy View Post
But to my original question, is there any reason to not permanently block off that gap? It seems like it's that way simply to make construction easier/cheaper.
I may not have been clear enough in one of my previous posts. Clean the inside corners of that lower sill and put a handsome dose of caulking in there before putting the window back in. That should seal the area up. I did the same thing. I even went so far as to round the lower corners of the aluminum window frames with a grinder so that the edges wouldn't cut into the caulking.
Old 11-12-2015, 03:10 PM   #13
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Heh - ok well my question is about whether to make it literally permanent, and you're suggesting a temporary (even if it's years) seal. I'll use epoxy caulk on it then ;)
My guiding principle at times is, "If someone else has this bus in 10 years, will they curse me for doing this?" If I actually epoxied the entire window in, I'd have a fantastic seal but never, ever get that thing out. But if I epoxy that gap and use std. caulk for the window, I don't think it's going to cause any grief.
Old 11-12-2015, 03:15 PM   #14
Equally as temporary or permanent as all of the other window seals... You need them all to work to keep the water out. Epoxy is a nice solution, though. You'll still want it in the same place as I mentioned earlier. Don't put it on the outside of the gap. It needs to follow the seam on the inside of the pane from front to back.
EDIT:
actually, I was just looking back at your pictures and it looks like the sides of the lower sill may have been welded to the ribs (first bus I've seen done like that). If that's the case and there are no holes in the welds then you might be able to apply the epoxy on the back of the gap. Just poke around and make sure there's no way for pooling water on the sill to drip down the ribs and into the wall..
Old 11-12-2015, 04:17 PM   #15
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
That pooling and dripping down the ribs into the wall is exactly what it's been doing over the years I've found. It gets in via those little gaps in the bottom corners.
Old 11-12-2015, 04:21 PM   #16
Well yes, of course I get that.. What I'm saying is to make sure that the seam along the whole 90 degree angle where the rib meets the sill is properly sealed. If you were to simply fill in that big gap at the back, but there were pin-holes along the sill/rib joint then water could still drip down along the rib and into the wall.
Old 11-12-2015, 04:30 PM   #17
Ok.. Pictures work best
So blue is the gap that you really want to seal. Good good..
Now, what I'm trying to get across is that the red line seam is even more important to have sealed up since that water will go directly down the rib and into the wall if there are any pin-holes in the weld, or if it isn't welded at all (it's hard to tell from the pictures. mine wasn't welded here at all). The green point in that little nook was a weak spot in my sills. It's worth making sure that yours is very well sealed.
Old 11-12-2015, 05:13 PM   #18
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Pictures FTW! Got it now, thanks!
Old 11-12-2015, 06:01 PM   #19
Jatzy has it exactly right as to prep and application and no silicone. Be certain to treat the areas you intend to seal with rust converter followed by primer prior to sealing things up. Jack
