Old 11-11-2015, 03:40 PM   #1
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Close off the gap at the bottom of a window frame to stop (some) leaks?
Like about anyone else with normal bus windows and old sealing, there are leaks at the bottom corners when it rains. Looking at the frame, it's kind of clear that the gap on each lower corner in the window frame is where it's most problematic, as pictured below...
Seems like a pretty easy fix here is to literally weld or otherwise seal off that gap. Then one mostly has to contend with water coming in the sides and top.
Has anyone else done this mod by chance? It seems like this might be a lot better solution than trying to load up the window frame with a ton of sealant. Still will need some, but perhaps not as much?
Thoughts?
Puggy is offline   Reply With Quote
Old 11-11-2015, 05:50 PM   #2
Hi. I'd offer a couple of ideas but it would be helpful to see the rest of the window frame with the window both open and closed. Do you want to open and close the windows after stopping the leak--I presume you do. Jack
P.S. I'll be heading off to a bus rally Friday morning until next Tuesday so unless you happen to reply by tomorrow evening I won't be able to respond until my return
Old 11-11-2015, 06:25 PM   #3
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
The bottom half of the windows is fixed, and just sent in caulking. Upper half slides up and down. I can take a picture tonite perhaps with the window out.
Old 11-12-2015, 01:16 PM   #4
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
This picture shows what the window opening is like, with the gap. Seems like a no-brainer to close that gap off for good rather than slather a ton of caulk in there.
Old 11-12-2015, 01:20 PM   #5
Chassis: B3800 Short bus
The trick is to not even let water get that far in behind the window. You want to clean the exterior joints and seal them with a thermoplastic caulking (NO SILICONE!!).
Completely seal the top and sides of the window and partially seal the bottom. Leave a small gap on the bottom-left and bottom-right so that if water does make its way back there it can still drain out.
For good measure, you can also clean (acetone works) those inner bottom corners where the water is currently leaking from and really goober that thermoplastic sealant into the corner before putting the window back in.
jazty is online now   Reply With Quote
Old 11-12-2015, 01:29 PM   #6
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
Jatzy - This may be a silly question, but why no silicone?
I have some small leaks in my windows too, and I'm trying to figure out the best way to seal 'em up. Ours seem like they're coming from the top of the window....you can actually see daylight through the tops of some of them - almost looks like a piece is missing.
johnbloem1974 is offline   Reply With Quote
Old 11-12-2015, 01:40 PM   #7
Silicone is just not meant for the job. There are many products which are designed specifically for exterior window sealing. Supra Expert is my personal favourite due to it being reasonably priced, resilient to huge temperature swings and able to stretch and squish without cracking . It can even be applied in sub-freezing conditions without issue.
The biggest problem with silicone is the clean-up. If you ever decide to replace a window you will be left with the awful task of removing all silicone. It tends to crumble. Thermoplastic caulking will pull out in stretchy strings once you get a hold of an edge.
Old 11-12-2015, 02:00 PM   #8
Engine: 190hp 5.9 Cummins
Good silicone don't crumble.
If I installed that window with silicone, and proper surface prep, you would never get the window out of the opening ever again.
As with any caulking, surface prep is everything.
Old 11-12-2015, 02:15 PM   #9
Rated Cap: 16
Thank you, gentlemen! Appreciate the info...
Old 11-12-2015, 02:43 PM   #10
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Definitely was going to clean and caulk the joint too.
But to my original question, is there any reason to not permanently block off that gap? It seems like it's that way simply to make construction easier/cheaper.
