Old 03-27-2014, 08:05 PM   #1
Year: 82
Coachwork: Grumman
Engine: Chevy
Combination Package
Found this picture on the web of a combo set in a train.
Has anyone seen this or known any info. Great for my
Small area.it looks like the refer is also part of it.
Alaska Stepvan is offline   Reply With Quote
Old 03-28-2014, 02:18 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Combination Package
Water and electric on the same surface... hmmm... I think I'd "pass" on that idea.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 03-28-2014, 02:33 PM   #3
Yup, gives a whole new meaning to the term "short sighted" Gas would be cool though.
Old 03-28-2014, 02:40 PM   #4
Sara's Avatar
I almost don't think it would be too hazardous. Think about a pot of water boiling over... the pan underneath should hold a fair amount of water. I speak from vigorous experience with overflowing pots and pans. As long as you're not running the tap on the counter itself (faucet doesn't reach) you should be fine! I'm assuming problems with water shorting out the stove portion would indicate that you have bigger concerns.
Sara is offline   Reply With Quote
Old 03-28-2014, 03:08 PM   #5
lornaschinske's Avatar
Rated Cap: 89
http://m.compactappliance.com/C48E-Summ ... /C48E.html
http://m.compactappliance.com/Summit-C3 ... /C301.html
Fulltime since 2006
Old 03-28-2014, 03:41 PM   #6
Year: 82
Coachwork: Grumman
Engine: Chevy
Originally Posted by lornaschinske
http://m.compactappliance.com/C48E-Summit-Stainless-Steel-Combination-Kitchen/C48E.html
Thanks.
Old 03-28-2014, 09:08 PM   #7
Year: 95
Chassis: GMC 3500
Engine: 6.5 diesel
if you google "kitchenette" you will get info on the combination units with the fridge.
snonbos is offline   Reply With Quote
Old 03-29-2014, 12:44 PM   #8
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
It would be cool if it was gas but as said.... water and electric.... Ill pass.
Old 03-29-2014, 05:30 PM   #9
Year: 1979
Chassis: IHC
Engine: 366
Rated Cap: 48
I take it none of you have heard of the showerhead with a 240Volt water heater? Apparently common down south america somewhere.
Richard
alwaysFlOoReD is offline   Reply With Quote
Old 03-29-2014, 09:56 PM   #10
Engine: 190hp 5.9 Cummins
Richard
And used across North America. Don't forget hot tubs, ect.
Nothing wrong with electricity and water as long as proper grounding and GFCI breakers are used.
Coach Work combination KyTireKicker Coach Conversion Projects 13 03-21-2014 01:57 AM
DIY combination potty/shower? Jaybus Plumbing, Water and Waste 2 08-09-2012 10:39 PM
CAT 1160 with 6spd Allison package FAST FRED Classifieds | Buy, Sell, Swap 0 06-04-2009 06:23 AM
