Old 01-06-2018, 03:02 PM   #1
Year: 2006
Chassis: IC bus
Engine: VT365
Rated Cap: 35C24A
Conversion questions
First... FLOORS... I have:
Removed seats and old floors.
Removed loose rust.
Grinded and wire brushed rust spots.
Had a body shop guy weld all holes and patch rusted through areas at the corners of one wheel well. Everything grinded flush.
Removed silicon from edges and corners.
Treated the entire floor with a "phosphatizing" solution, then washed floor.
Treated entire floor with rust converter.
Painted with a quality primer.
was able to get rust converter under the driver seat plate with a sponge on a stick but the primer is thick. Any ideas?
http://www.skoolie.net/forums/member...ture17899.html
still to do...
Recaulk the corners and edges.
Install flooring.
Am I missing anything?
Is the primer enough or do I need paint on top.
Tyania is offline   Reply With Quote
Old 01-06-2018, 03:13 PM   #2
Jdawgsfanasty's Avatar
Removed loose rust.
still to do...
Install flooring.
Lots of work! Do folks undercoat vehicles? Seems to me that a undercoat makes more sense...but idk, just asking
Jdawgsfanasty is offline   Reply With Quote
Old 01-06-2018, 05:04 PM   #3
Robin97396's Avatar
Tyania; The floor sounds good. The primer should be adequate but I'm sure there are other opinions.
You might want to lay down a little insulation before the floor or subfloor if you're intending to air condition.
Jdawgsfanasty; Some have undercoated. Some have foamed from under the floor. I wanted to foam under the floor but there's a lot of stuff in the way that makes that difficult.
Robin
Nobody's Business
Old 01-06-2018, 05:08 PM   #4
That makes sense too...thx
Old 01-06-2018, 06:39 PM   #5
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Rubberized undercoating seems like a good thing --- until small holes form, the rubber starts peeling, allowing water to enter the space and stay there. My sister had a Toyota Tercel in the N.C. mountains with an undercoating. They salt the roads there in winter, and I thought "Wow this is great!" Everything looked perfect. I put a jack under the frame-rail, and it crunched. All Rust....
Paint and primer flake away, or show the rust starting to bubble underneath, allowing you to fix it before it gets bad, and don't hold water against the metal.
Old 01-06-2018, 07:03 PM   #6
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
I'm going to do several inches of foam board and then metal as my sub-floor. It won't ever rot and you can fit more insulation underneath to make up for what the plywood thickness would have been.
Thomas1985 is offline   Reply With Quote
Old 01-06-2018, 07:20 PM   #7
Robin97396's Avatar
That sounds like a good way to save 3/4". That metal flooring might be handy if you had hydronic heating.
I agree about the undercoating, and even exterior underfloor sprayfoam. A rock hits the undercoating allowing water to find an entry point into the body panels. I'd expect virtually the same from underfloor spray foam, unless its factory.
Robin
Nobody's Business
Old 01-06-2018, 09:08 PM   #8
Year: 2006
Chassis: IC bus
Engine: VT365
Rated Cap: 35C24A
We are thinking of eventually corro-seal painting (Mexican available rust converter) the underside of the bus. Our bus came from NY so even though the school did a fair job at regularly spraying the underside, there is rust. Where we live, there is no sand blasting available. Anyone have experience using a rust converter on the underside? How much prep (cleaning, sanding, sandblasting) did you do first?
Old 01-06-2018, 10:02 PM   #9
Chassis: Saf-T-Liner MVP ER
Just brush off the loose stuff and "Ospho" what remains.
Steve Bracken
Build Thread
Old 01-06-2018, 11:19 PM   #10
Thx for insight...
