Old 10-29-2005, 05:43 PM   #1
Elliot Naess's Avatar
Engine: 5,9 Cummins
Convert Ford B700 from gasoline to diesel engine?
I'm getting ahead of myself again, but there is this Ford B700 with Ward body very conveniently for sale near my house. Looks to be 1980-ish. And it's a stick shift! Trouble is, it has a gasoline engine (badge says 429 4-barrel). Has anyone converted one of these to a diesel engine? Any thoughts?
Always brainstorming -- trying to be ready when a bargain appears.
Elliot
Old 10-29-2005, 06:21 PM   #2
Coachwork: Ward Genesis
Engine: DT466/MT643
Don't bother...it's much easier to simply buy a diesel bus. A gas to diesel conversion is a MONUMENTAL job.
Jarlaxle
Old 10-29-2005, 06:27 PM   #3
Engine: 5,9 Cummins
That settles that!
Thank you -- that settles that! I just "had to" explore the idea since that bus is right here in town.
That settled, I see many other B700's in these parts. And you have one. Anything I might want to know about them if I find one with diesel power?
Much obliged,
Elliot
Old 10-30-2005, 03:18 AM   #4
lapeer20m's Avatar
Agreed!
Old 11-10-2005, 07:16 PM   #5
I thought about a deisel conversion if (when) my gas motor gives up. On second thought maybe a well built fuel injected big block chevy. Enough low end torque and maybe fuel economy wouldn't be so bad...... just a thought.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 11-11-2005, 10:48 AM   #6
lapeer20m's Avatar
Gregg the bus guy said that he is real pleased with the 454 efi.
Old 11-13-2005, 06:50 AM   #7
Diesel conversion
If you are mechanically inclined and a little good at wiring and diesel conversion is not at all hard. Espesially a 6.9 or 7.3 diesel from navistar. The 6.9 only requires a hot wire to the fuel shut off solinoid another for glow plug wiring solenoid and the in line fuel heater. Use you factory altenator. And your good to go. Take a trip to the scrap yard and compare a diesel bus to yours
Supercrewzer76 is offline   Reply With Quote
Old 11-13-2005, 11:23 AM   #8
Engine: DT466/MT643
Don't forget:
Engine mounts.
Exhaust.
Cooling system.
Will the laternator bolt to the engine in the same place.
Fuel system will have to be completely reworked.
Gotta dig up a trans bellhousing & clutch assembly.
Probably will need to regear the axle.
Better to just buy a factory diesel.
Jarlaxle
'87 Detroit Diesel 8.2L Ford B700 conversion -- help! caster Veggie Oil | WVO | Biodiesel | SVO 0 07-18-2014 10:37 AM
convert gas to diesel engine waterboy434 Conversion General Discussions 3 02-22-2010 10:52 PM
Pics of 87 Ford B700 Blue Bus 6.6 Diesel lapeer20m Skoolie Conversion Projects 29 06-29-2008 05:12 PM
Run Away Diesel! - '88 Ford B700 Won't shut off. jasonvandyke Conversion General Discussions 3 08-19-2007 09:29 PM
86 Ford B700 Turbo Diesel TravelingMan Conversion General Discussions 0 03-12-2005 02:01 PM
