Old 07-16-2017, 06:18 PM   #1
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
converting bus into a trailer
I was thinking about maybe getting a new bigger bus...but it's hard to let go all my hard work. I have instead thought about maybe making a bus trailer for towing behind my bus. I think maybe airbrakes...I'm not sure electric would be enough. What are your thoughts?
rock649 is offline   Reply With Quote
Old 07-16-2017, 06:19 PM   #2
seems like a bus has the wrong weight distribution to be a trailer? crazy heavy tongue weight?
Old 07-16-2017, 07:56 PM   #3
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Maybe need a 5th wheel trailer dolly?
Tootalltechie is offline   Reply With Quote
Old 07-16-2017, 08:19 PM   #4
is that something that effectively adds a set of wheels to the front of a trailer but still allows for a hitch-pull?
Old 07-16-2017, 08:45 PM   #5
Year: 1974
Rated Cap: 48
Correct Christopher, or something like that.
Here is a YouTube video showing the dolly.
https://youtu.be/rhK3H3Uf4Bg
Old 07-16-2017, 11:14 PM   #6
would be easy just to buy old travel trailer n gut it or change as desired. however, of course it is possible to cut off the front of the desired bus-trailer and remove the spring hanger rivets n move the rear axle assy up forward to make a properly balanced trailer. of course, tongue n brake system is essential. changing rear suspension types, extending or shortning frames is very common for trucks.
Also would not be difficult to buy two or three mobile home axles with brakes and build your own trailer... trailer supply places even have the normal type of hubs, etc for regular wheels...
Old 07-19-2017, 11:34 AM   #7
I would think that the weight overall, not just the tongue weight, would be a big concern.
A thought that I had entertained was to purchase a junk travel trailer and stripping it to the frame. Then, build a new structure on the frame that matches the bus appearance.
Just a thought.
