Old 05-19-2016, 06:10 PM   #11
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Magnets do not stick to stainless steel.......
My build thread - viewtopic.php?f=9&t=467197
Old 05-19-2016, 06:15 PM   #12
Chassis: International S3800
im guessing my stainless steel cookware must not be all stainless then.. as it works on induction.. so must be just a stainless steel coating perhaps on the inside of the pan
Old 05-19-2016, 06:18 PM   #13
Jolly Roger's Avatar
Engine: Detroit 8.2
Magnets do not stick to true stainless steel but they will stick to almost any stainless steel appliance sold to you.
Real stainless wont hold a magnet and if you want to work with it. You better have the right tools cause you will waste your time and money with the cheap tools.
Old 05-19-2016, 09:13 PM   #14
All comes down to the grade of the stainless. Magnets will stick to all of it that has a high enough percentage of ferrous metal in the alloy. Low ferrous content will not hold a magnet. That is generally regarded as "the good stuff" since it is more rust resistant but it really depends on what the alloy was intended for. Knives typically need a higher ferrous content to hold a decent edge for example.
Old 05-20-2016, 08:42 AM   #15
Chassis: B3800 Short bus
Word. The only tool that I own that will work with stainless is the angle grinder! I tried a jigsaw with metal blades, a hole saw and hand tools, but they didn't "cut it".
jazty is online now   Reply With Quote
Old 06-07-2016, 06:39 PM   #16
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Tried to "bake" biscuits this morning on the cooktop. Well, I achieved about a 95% success rate. I set it up for 11 minutes at 375 and watched through the glass lid. Right idea, wrong mechanization. I had to remove the bottom 5% of each biscuit, as it had turned to charcoal. Next time, I'm trying a longer cook time at a lower temp.
