Old 05-17-2016, 08:14 AM   #1
Cook Top
Saw this cook top on Woot.com and thought some might be interested for their builds. Would have to run off generator or shore power but the price is great and looks like it might work nicely.
Caso Induction Cooker-Your Choice - Home.Woot
dgorila1 is offline   Reply With Quote
Old 05-17-2016, 11:06 AM   #2
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Very neat!
But i'd need an extra genny just for it
n00b build > https://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 05-17-2016, 04:18 PM   #3
tincaneasybakeoven's Avatar
Year: 95
Coachwork: Amtran ss-33
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
wife says special induction cookwear required
claim common law i, a man; claim.... on facebook
if your not a man our doing it all wrong-kp
tincaneasybakeoven is offline   Reply With Quote
Old 05-17-2016, 04:22 PM   #4
Coachwork: Ward
Wifey would be right!
Sent from my Nexus 6 using Tapatalk
Old 05-17-2016, 05:05 PM   #5
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Only SPECIAL induction cookware necessary is that it cannot be aluminum. If a magnet works on it, cook with it.
Old 05-17-2016, 06:37 PM   #6
Jolly Roger's Avatar
Engine: Detroit 8.2
Campmore.com sells cooktops.
I have a propane cooktop from them that is great if you like propane?
We plan on cooking on a campfire 90% of the time so no oven, only Dutch oven and coal style and my 15-16yr old boys have some meals (breakfast and supper) down patt. I only care about a cooktop in the house/bus to make perculater coffee before the fire is going? Of course I could hook up the electric one but if I ain't at home I am having real food and real coffee? Propane works inside. Just provide an exhaust fan when cooking and a carbon monoxide sensor at all times(just like a fire alarm).
Old 05-18-2016, 04:47 PM   #7
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Wifey is WRONG. I have an induction cooktop and I use my stainless steel and cast iron on it. And you don't need another genny, either.
Old 05-18-2016, 05:04 PM   #8
Coachwork: Ward
And I bet your significant other want reading while you were typing!!! LOL
I would need a 2nd genny, I only have 2KW
Old 05-18-2016, 05:41 PM   #9
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
What SO? I'm still footloose & fancy free.
I'm running mine on a 20a circuit.
Old 05-18-2016, 06:45 PM   #10
correct you sont needspecial cookware.. justr cant use aluminum.. you can use iron, stainless, steel and such.. but not the all common anodized aluminum cookware...
like others have stated if a magnet attaches to it solidly then it will work
Old 05-19-2016, 06:10 PM   #11
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Magnets do not stick to stainless steel.......
Old 05-19-2016, 06:15 PM   #12
im guessing my stainless steel cookware must not be all stainless then.. as it works on induction.. so must be just a stainless steel coating perhaps on the inside of the pan
Old 05-19-2016, 06:18 PM   #13
Engine: Detroit 8.2
Magnets do not stick to true stainless steel but they will stick to almost any stainless steel appliance sold to you.
Real stainless wont hold a magnet and if you want to work with it. You better have the right tools cause you will waste your time and money with the cheap tools.
Old 05-19-2016, 09:13 PM   #14
All comes down to the grade of the stainless. Magnets will stick to all of it that has a high enough percentage of ferrous metal in the alloy. Low ferrous content will not hold a magnet. That is generally regarded as "the good stuff" since it is more rust resistant but it really depends on what the alloy was intended for. Knives typically need a higher ferrous content to hold a decent edge for example.
Old 05-20-2016, 08:42 AM   #15
Chassis: B3800 Short bus
Word. The only tool that I own that will work with stainless is the angle grinder! I tried a jigsaw with metal blades, a hole saw and hand tools, but they didn't "cut it".
Old 06-07-2016, 06:39 PM   #16
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Tried to "bake" biscuits this morning on the cooktop. Well, I achieved about a 95% success rate. I set it up for 11 minutes at 375º and watched through the glass lid. Right idea, wrong mechanization. I had to remove the bottom 5% of each biscuit, as it had turned to charcoal. Next time, I'm trying a longer cook time at a lower temp.
