Old 12-13-2018, 06:38 PM   #1
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Coolant line to heater: Which one goes to heater?
These are the coolant lines that run to the heater I removed approximately 10 months ago. I am ready to hook up my new heater. It specifies that the coolant travel in a certain way (inlet vs outlet).
Is there a way I can tell which one is to the heater? I don't see any specific markings. I assume that if I open either of them coolant will come out but that doesn't let me know which one is the feed.
6.6 liter New Holland diesel (1990)
ID:	28153Click image for larger version
Nick
Old 12-13-2018, 06:46 PM   #2
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
If yours is like mine, one of the lines can be traced to the vicinity of water pump. That should be the supply. A trick I used when plumbing my heater back in was to buy a length of clear vinyl tubing with the same ID from the local hardware store and to plumb it in where the heater core would be with a purge faucet.
It allowed me to see the progress of the bleeding and purging.
Something like that might help you as well.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 12-13-2018, 07:00 PM   #3
Ninjakitty's Avatar
Attachment 28155
Thank you, that is a great idea.
Nick
