Old 02-20-2017, 07:07 PM   #1
mdeese's Avatar
Chassis: GMC Vandura 3500
Engine: 5.7L
Covering up roof emergency hatch
Anyone have any experience covering the roof emergency exits up? I was thinking of just riveting/siliconing a piece of sheet metal, any reason this wouldn't work?
My build thread
https://www.skoolie.net/forums/f11/l...-ii-16801.html
mdeese is offline   Reply With Quote
Old 02-20-2017, 07:16 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Don't see why it wouldn't, give at least an inch of overlap, and paint liberally with an elastomeric paint.
Should be water tight.
I have seen it in a few other threads on here. Sometimes to close it up permanently, sometimes to.ahrink the hole to fit a fan.
Old 02-20-2017, 07:28 PM   #3
roach711's Avatar
Rated Cap: 19
I used a piece of fiberglass that I removed from the inside of the bus to cover mine. Used butyl tape under the fiberglass sheet and some Henry 212 clear sealant over the screws and edges.
Someone here on Skoolie put a skylight over his.
The Roach Motel
Old 02-20-2017, 07:48 PM   #4
Just get some steel and some body panel seam sealer. Rivet it down, and you're good.
Old 02-20-2017, 09:40 PM   #5
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I used rivets & seam sealer on mine
Old 02-21-2017, 08:11 AM   #6
Engine: Navistar 7.6L
used some aluminum sheet, just a bit larger than the old hatch frame.
Clean off the old butyl tape gasketing, smack down the old screw holes with ball peen hammer, wipe surface off with starting fluid.
Put down new butyl tape and screw it down with Tek screws (with sealing rubber and washer combo).
You want to follow the line of fasteners that held the hatch in as they are or should be going into the internal ribs and some other channels pieces.
Do not try to hit the old screw holes with the new ones.
DoubleO7 is offline   Reply With Quote
Old 02-21-2017, 12:53 PM   #7
Justin McCormick's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: Cummins 5.9L Diesel Engine
Rated Cap: 83
Thats what i did with mine, seems to have worked well.
Follow our bus blog here -
https://www.wildernesswandering.com/
Justin McCormick is offline   Reply With Quote
Old 02-21-2017, 01:44 PM   #8
mdeese's Avatar
Engine: 5.7L
What gauge sheet metal is that?
My build thread
Old 02-21-2017, 02:07 PM   #9
Rated Cap: 83
I did not measure it, but its from the celling panels which seemed pretty thick, at least as thick as the roof itself.
Old 02-21-2017, 04:10 PM   #10
Aluminum will work, but steel is cheaper, easier to work with, and won't cause any galvanic corrosion.
Old 02-21-2017, 05:52 PM   #11
Unless your roof is Aluminum.
Old 02-21-2017, 06:34 PM   #12
Rameses's Avatar
You uppity punks with your Crowns. Think you're so fancy with your aluminum bodywork.
Man, I want one of those things. Bad.
Rameses is offline   Reply With Quote
Old 02-21-2017, 06:48 PM   #13
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Man, I want one of those things. Bad. [emoji3]
You and me both. Lol.
East coast problems 😎
Old 02-21-2017, 06:51 PM   #14
tobeamiss's Avatar
Looks good! This is something I've been thinking of doing.
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 02-21-2017, 08:53 PM   #15
True that.
Most of us don't have them fancy luxury liners yall get out there!
Old 02-21-2017, 09:03 PM   #16
mdeese's Avatar
Engine: 5.7L
Thanks for the input gentlemen, I put the order in at the metal shop this afternoon. Should have my window inserts and hatch covers ready to install this weekend.
My build thread
Old 02-21-2017, 09:09 PM   #17
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Are you going to skin the windows or build "blanks" and put them in the window frames?
Old 02-21-2017, 09:09 PM   #18
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Are you going to skin them or build blanks to go in the window frames
Old 02-22-2017, 09:13 AM   #19
rjnye79's Avatar
Engine: T444e
I removed the hatches and covered the holes with plexiglass. We now have two skylights. They're wonderful when camping in mild climates, but have to cover them from the inside when it's cold so we can retain heat.
rjnye79 is offline   Reply With Quote
Old 02-22-2017, 09:32 AM   #20
mdeese's Avatar
Engine: 5.7L
I have 25inx29in individual sheets that I will be riveting into the window frames from the inside of the bus.
My build thread
