Old 06-10-2012, 06:13 PM   #1
Coachwork: Ward
Chassis: Crane Carrier
Crane Carrier chassis
Greetings all I'm new to skoolies but have converted a highway coach and had a few questions:
1991 Ward Senator
Crane Carrier Chassis
5.9 cummins at545
1st -anyone have this bus and successfully converted it?
2nd - what the heck do I do with the doghouse area and the wheel wells?
3rd - anyone go to 24.5 tires and gain anything?
And these are just getting me started ;)
Serenity is offline   Reply With Quote
Old 06-12-2012, 04:04 AM   #2
Re: Crane Carrier chassis
1-no
2-climb over them i guess, since its a FE
3- since you have a 545 transmission, depending upon your rear axle ratio, the 24.5 tires will get you a bit more speed.. however... speed is determined by the circumfrence of the tires, not wheel size. busses that go up and down a lot of steep hills all the time would be better off with smaller circumfrence tires but since 24.5's are mostly all larger in size than the 22.5's circumfrence, they are better for level freeways...
Old 06-12-2012, 02:59 PM   #3
Coachwork: Ward
Chev49 your on the other boards aren't you? She rolls out at 70 with pedal left no problem so I'm not concerned so much about speed as the BOUNCE!
Chassis ID imfree Cummins Drivetrain 5 12-11-2011 09:13 AM
tractor trailer/cargo carrier conversion? baadpuppy Conversion General Discussions 20 05-27-2009 02:59 PM
BB on IHC chassis frank-id Classifieds | Buy, Sell, Swap 4 04-05-2008 08:32 AM
What's the minimum size gennie I need to run a Carrier Air V odyssess Conversion General Discussions 2 08-01-2007 03:54 AM
Armored Personnel Carrier dammitAndy Everything Else | General Skoolie Discussions 4 12-13-2005 08:18 AM
