Originally Posted by Qya1991
Okay thank you for the heads up. What would be a good metal jug to use?
Sent from my SCH-I545 using Tapatalk
im not sure what others use.. another option is a CCV vent system.. my Bird came with a RACOR CCV-3550 installed.. it catches and recirculates the oil back into the pan. and then filters the gasses and runs them back through combustion.. its more an emissions thing but it has the side effect of recycling the oil. I was going to yank it off till i realized what it does.. so i fixed it.. and seems to have made my oil leaks nearly non existent.
as for a jug whatever you do DONT seal that tube against the jug... if you block the flow of gasses from that tube you will blow out every oil seal in that engine..
