Old 07-08-2015, 10:27 PM   #1
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
Creating valves for black tank
I have a bunch of polyethylene jet ski tanks lying around. I'm planning to put two ~16 gallon tanks together for each of the grey and black water holding.
I bought a couple of these:
Amazon.com: Valterra T40 3" Hub x 3" Spigot Valve Assembly: Automotive
Sliding valve assemblies.
I'm hoping that I can put a hole in the bottom of the tank, slide one side in and seal/glue it. Has anyone made their own tanks like this? What kind of sealant did you use?
My build thread:http://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 07-08-2015, 10:46 PM   #2
rvingoffgrid's Avatar
Coachwork: happy camper RV repair
Chassis: international
Engine: 360 international
Rated Cap: 66 passenger
I would weld it and not use sealant/glues you can get plastic welding equipment from Amazon, some requires a shield gas just like welding metals. But once your set up plastic welds very similar to metals. Be sure not to weld the valve on but weld a flange on for the valve then install the valve to that flange, also unless the tanks are square they won't make good black tanks
rvingoffgrid.com
rvingoffgrid is offline   Reply With Quote
Old 07-08-2015, 10:51 PM   #3
Chassis: Thomas
Rated Cap: 60
The tanks have a gentle v-shaped bottom. Some of them have 9 bolts around the top hole. We were thinking of turning the tank upside down and bolting a fitting to it that would let us attach the valve.
Old 07-08-2015, 11:30 PM   #4
Black tanks need to sloop towards the drain otherwise you will have problems draining it
rvingoffgrid.com
