Old 03-31-2004, 04:05 AM   #1
Jeff in AK's Avatar
Creative Condensation Control
Well known is the 12vDC fan’s efficiency for circulating air for condensation control, but what about solar fan vents? Are they efficient? Do they make a good secondary energy saving alternative? If so, what name brand?
What about non-mechanical roof ventilation? I know boats use cowl vents and wind scoops to circulate air in lower cabins, but will this passive kind of system work well in a skoolie? Sure I can open a window, but weather conditions and noise control makes me want alternatives. Anybody have any thoughts on this matter? Any response is greatly appreciated. Thanks!
Jeff
Jeff
1986 International Carpenter
(Retired from City-Glacier Tours)
Jeff in AK is offline   Reply With Quote
Old 03-31-2004, 08:49 AM   #2
Les Lampman's Avatar
Hi Jeff,
The solar fans and cowls will do the same thing for your bus as they do for the boat. One reason that the non-powered wind scoops and cowls are effective in a boat is because at anchor the boat points into the wind. The bus won't do that so you'd need to adjust your cowl vent to take advantage of the wind direction. The solar vents wouldn't have that problem. The brand I've most often used is Nicro but I'm sure other would work just fine. For the fan to work effectively at ciculating the air you want to provide an air inlet somewhere; hopefully at the other end of the bus so the air is drawn the full length.
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 04-13-2004, 05:43 AM   #3
Jeff in AK's Avatar
Hi Les,
With your boat building experience and your plans to build a full time live aboard, will you use a solar fan with an air vent at the other end of the vehicle? Outside of the costs, it just seems to make a lot of sense. What do you think?
With all the bus conversion information available on the internet, I am shocked that there is not more reference to boat systems & function. A boats functions are much more demanding. There seems to be a bus conversion expert everywhere and not enough boaters into bus conversions. Maybe the boat community thinks we Bus enthusiasts are just a bunch of land lovers.
Jeff
Old 04-13-2004, 09:56 AM   #4
Hi Jeff,
In a way a lot of RV's do have a system similar to what you're thinking as quite a few have roof vent units in multiple locations on the roof; many of them are powered vents.
I don't see the solar vents as being as much advantage in a live-aboad bus since folks are there to open windows, vents, doors, etc. For a bus that's not bing actively used they might be nice so that they're working full time even when the bus is unoccupied.
I think a lot of conversions are done based on what we see on manufactured RV's; the prime consideration there (until you get to the high end) is cost and ease of construction (plant efficiency) with relatively unskilled labor. If I were converting a weekend camper I might choose different materials and equipment than I am for converting a 'rolling home' fulltime live-aboard bus. If something breaks on our bus I know who's going to fix it and I know how much stuff is going to be in the way when it needs fixing. I'm doing everything I can up front to minimize the chances of failures and enhance efficiency by using the best materials and components I can. I naturally draw from my boating background.
As has been said here many times; there's no "ONE WAY" to do anything. As long as things are done to maximize safety there are any numbers of ways to "get the job done". Depending on my energy level (and financial level!) my conversion thoughts (for many years now) have run the gamut from bolting down a queen-sized bed in the back, installing the woodstove, throwing in the big floor pillows and installing a curtain around a portable toilet to where I am today with plans to do it once the best way I know how so that it will last the 20 years I need it to. [Of course, as soon as I do something I'll think of a better way to have done it...faster, cheaper, or better looking but that's part of the process!]
I'm learning a lot by hanging out with all these crazy folks (if we weren't crazy we'd just go buy a motorhome and head down to road). I may have a good background in 'systems' like plumbing, electrical, heating, etc, but I'm gaining invaluable knowledge in the areas where I don't have any particlular expertise (or even basic knowledge) like painting the bus, flooring, insulation materials, sound deadening, welding brackets, and more.
I'm having fun and at this stage, that's what it's all about. I don't have any 'end date' for my project and I'm moving at a snail's pace. This is a busy time of year in the boat biz so I don't have much time available and I have a motorcycle I love to ride and the weather has been nice!
We go on vacation every year in the first week of October; there are four adults and four dogs and we head down to Lake Shasta from northwestern Washington. This year I hope to have enough of the basics done that the bus can be our transportation. We have a 1977 Beaver Class C motorhome (on a C30 Chevy chassis with a 454 engine) that we usually travel in and that would still work but I think it would be a blast to take the skoolie instead.
Les Lampman
Skoolie.net Gallery
Leaking roof or condensation? 1waxhat Conversion General Discussions 5 12-27-2016 08:24 PM
How do I prevent condensation in ceiling? jjhomeonewheels Conversion General Discussions 3 11-27-2012 02:49 PM
Cruise control somewhereinusa Conversion General Discussions 6 02-01-2011 08:27 PM
Window Condensation in Cold Weather arfisher83 Conversion General Discussions 10 02-17-2008 10:33 PM
Cruise Control Les Lampman Conversion Tutorials and How-to's 5 03-03-2004 09:34 AM
