Old 04-25-2018, 08:14 PM   #1
Chassis: Tandem Super Coach
Engine: Cummins 220
Rated Cap: 90
Crown Ceiling Removal
So can anyone tell me how to start removing the ceiling panels from a Crown bus?
iusvir is offline   Reply With Quote
Old 04-25-2018, 11:12 PM   #2
Rated Cap: 37,400 lbs GVWR
Why?
You have A LOT of rivets to drill out, then you have to consider how you'll fill the resultant gaps above the wiring chases over the side windows. Think very carefully before taking down the ceiling, because there's no going back if you change your mind later.
Old 04-26-2018, 03:14 PM   #3
Engine: Cummins 220
Rated Cap: 90
Rivets What Rivets?
So that seems to be t of my problem, I don't have any rivets holding the roof panels up, they seem to be some sort of standing seam.
Old 04-26-2018, 03:26 PM   #4
Post a close up pic of your ceiling.
