10-03-2015, 09:03 AM
Cubicle walls as building material
Cubicle walls seem to be readily available in my area. They seem fairly light, sturdy and have good sound deadening ability. It seems they could be useful as a bathroom enclosure for example. They would of course need to be covered inside with frp or the like.
What I can not seem to find is what is actually inside of them. I cant seem to locate any pics of them being built.
What is inside of them?
Do they have any junk wood?
Any insulation?
Steel bracing?
Any thoughts insights or ideas would be appreciated.
10-03-2015, 09:28 AM
Any insulation?
Steel bracing?
From the ones we destroyed at work (don't ask stagehands to care about building your office)
Depends on the brand.
Like plywood and particle board, then yes.
no.
They can.
My thoughts: They could make for a really nice steel tent internal walls, but I wouldn't want to use them. That and you would always feel like you were in an office.
10-03-2015, 12:00 PM
Engine: 190hp 5.9 Cummins
Metal frames covered with fabric. The fabric absorbs the noise.
10-03-2015, 12:17 PM
So is there enough metal to use them as framing for walls? Then add foam insulation, and put desired skin over them?
10-03-2015, 11:13 PM
Hard to say. You will have to decide that for your self.
10-04-2015, 12:13 AM
I doubt it will save you much time retrofitting vs building from scratch although the way they hook together could save some time... still unless you get them for free I think you will be over paying.
10-04-2015, 02:05 AM
Chassis: Chevy P30
Engine: Chevy 6.2L Diesel
Another stagehand/Audio Engineer here...
If you find them for free, you might as well take them... But I wouldn't go looking for any--You'd be better off in just about every department building something like them from scratch. Honestly, even if I had a few in my backyard, I don't think I would use them or any part of them in a bus build. The only thing I think I might use would be the outer fabric, and that would only be if they were from a brand that used some sort of proper acoustic cloth on the outside.
10-04-2015, 11:52 AM
If you have the skills and the tools, one inch square tubing is cheap framing material and takes up less room then a 2X4. Every inch counts if you are building a short schoolie or van. MIG welders are relatively cheap and its pretty easy to learn to weld with one. Once you have the welder ... you can do many projects you couldn't do otherwise.
I bought all the steel I'm going to need (about 100 feet) for the bathroom, dinette, storage racks and (kitchen) counters for about $60.00
Instead of wallboard or plywood wall covering, I'm using plastic sheets. Home Depot has a couple different thicknesses.: woodhttp://www.homedepot.com/p/PLASTEX-1-16-in-x-4-ft-x-8-ft-Plastic-Panel-63003/202090190
If you need insulation, it shouldn't be too hard to find foam one inch thick.
For the "crafty", covering the plastic shouldn't be too hard.
10-04-2015, 09:33 PM
I 100% agree with this way of thinking. This method is far better than using 2x4's and plywood for interior framing.
FRP also works great for finishing interior walls.
10-05-2015, 05:50 AM
I know how to weld. My dad has a mig welder that I can borrow. The only downside is that it is 240v and the custom extension cord for it is only about 35' long. Im not sure that my generator is big enough to run it or if it is compatible. I suppose we could drive it to his place to frame it out. I did not realize that square tube was so cheap I will look into that.
I suppose that I could use my oxy/acetylene to weld it up, I am a lot more skilled with a MIG or TIG welder but l know that I would get the hang of it quickly if I had no other option. Plus the welds would be hidden so they'd just have to be structurally sound. I have only welded sheet metal with gas, which is much more difficult because its so easy to put too much heat into the surrounding area. That wouldn't be an issue on tubing.
If we can frame it out for $60 or so I'd be happy.
10-12-2015, 11:07 PM
$60 PLUS the wall coverings, PLUS the insulation, PLUS the cost of the equipment used to weld all these together, not counting electricity or gas to power your welder, PLUS your time.
I think if you can get free cubbie walls, the modifications to retro fit into a bus should be minor vs building from scratch. Haven't pulled the cloth off any, but I would assume that would be minor, which would leave you with just insulating the inside.
Personally, having spent toooooooo many years surrounded by those walls I would not even consider them.
Just my 2 cents, my thoughts on paper. (As I've been told "if you don't know what your talking about....don't talk).
10-12-2015, 11:34 PM
Thanks for the insight. I may try to pick some up, we will see. Don't worry, We would not leave them uncovered.
