Old 11-22-2019, 12:41 PM   #1
Chassis: IH 3800
Custom shower pans?
Hey alls..
Been tossing ideas around about building a custom shower/toilet combo pan.
After doing some digging, I found that you can get stainless replacement dog kennel trays in all sorts of sizes that might work really well... and are relatively cheap.
https://www.amazon.com/Pinnacle-Syst...es&sr=1-1&th=1
Thoughts on using something like this? You'd need to run the wall liner down inside the tray and seal it up... could even raise a portion of the tray and taper the bottom a bit easily enough when you install the drain.
Anyways.. open to other ideas. Not really wanting to spend $400+ on a shower/toilet combo pan.
Old 11-22-2019, 12:48 PM   #2
Originally Posted by Mr4btTahoe View Post
Hey alls..
I just got a residential pan. I might need to build up the fiberglass or add wood under the toilet, but it won’t be a thing. I got the closest size I could find to making it between windows. I’ll have a 4” deep shelf inside to get the wall between windows.
Old 11-22-2019, 01:04 PM   #3
Engine: 466DT
I've been tossing this issue around in my head as well. Good grief, shower pans are expensive! (I don't remember paying this much for one when I built my "real" house.) . Even the drain assembly is like $80!
Been toying with the idea of a building a mortar pan but worry a bit that it will crack over time.
A pastic horse trough from Tractor Supply is $80. Maybe you could cut the sides off that.
ted@campbycanoe.com is offline   Reply With Quote
Old 11-22-2019, 01:23 PM   #4
That kind of thinking outside the box helps us heaps. We had to abandon our plans to install an RV tub because it was just a tad too big. We found a plastic utility sink on sale at the hardware store, trimmed it out in aromatic cedar, and it works brilliantly....looks a little like a spa tub. Sometimes you need to repurpose unusual items when skoolie building.
