10-05-2015, 09:30 AM
Custom water tanks?
So I think I know what I am doing here but I figured I'd ask? I would personally rather fit my water tanks to the bus than build around them. I am looking at raising the floor of my bus up to the seat rail to accommodate some things.
One of those things being keeping the water tanks inside the bus where they will be in the climate control. My first thought was to find plastic tanks. Nothing I have found either fits my needs or falls in my budget. My new thought is Plywood...
I did some research a while back on plywood fish tanks. Basically what you do is frame the outside like you would a wall, line the inside with plywood, then fiberglass the plywood to make them water tight.
Other than sacrificing a bit of real estate for wall thickness I think this may be the best option for my budget. Any thoughts?
10-05-2015, 10:14 AM
Personally, wood tanks sound pretty scary. Fine in a house...that is sitting still...but buses flex and vibrate constantly. It may be possible to frame something up that could withstand traveling rough roads and the huge inertial forces water creates by simply starting & stopping...but...the potential consequences of even a relatively minor failure would steer me in a proven direction (welded metal or plastic).
Just my dos centavos pardner.
10-05-2015, 12:36 PM
Chassis: Blue Bird
Engine: ISC 8.3
I don't know.. I guess it depends on the ratio of wood to fiberglass? Make the 'glass thick enough and it'll probably do just fine! But don't ask me what "thick enough" looks like; I've no idea..
Have you looked through the Inca Plastics catalog? You can tell they're in the business of making tanks, not web sites and sales materials, but if you can get past that they have quite a variety of options. I bought several tanks from them for my bus. It worked out particularly well because I "needed" to make a trip to the southern California area and they weren't too far out of the way to stop by their factory and pick up the tanks, saving the shipping cost.
10-05-2015, 02:56 PM
I have thought about the strength while driving. My solution there would be to build the tank with baffles. there is also the option of a steel frame as structure with a wood/fiberglass lining. I'm leaning this route in effort to save money on materials where plastic is outside my abilities to do myself and assuming the metal option is stainless that is way outside my budget. I guess I like the steel frame idea too because I can do the frame a lower profile to gain more volume.
10-05-2015, 07:38 PM
Engine: 190hp 5.9 Cummins
This topic comes up on this site a few times a year.
I would never use a plywood tank in a mobile vehicle.
Plastic tanks are made in every size and any size. They can also be custom ordered.
You won't build a plywood / fiberglass tank for what the plastic ones cost. Plastic will always win cost wise and durability.
10-05-2015, 07:42 PM
Mind sharing a source? Because the plastic tanks that I'm finding anywhere are not the right size and the ones in a similar volume are over $1k each...
10-05-2015, 09:01 PM
Chassis: Blue Bird
Engine: ISC 8.3
Well.. I guess you didn't really indicate any particular volume; I just assumed 40-50 gallons per tank. IIRC mine are 42 gallon and cost around US$180 each.
On a related note, it might be more fair to compare plastic to fiberglass and ignore the cost of the plywood. Ameri-Kart recommends their plastic fresh water tanks be boxed in with plywood for reinforcement. That might not be so different from the plywood box one would line with fiberglass.
10-06-2015, 07:22 AM
Chassis: TC/2000
Engine: Cummins 5.9TA
I'm thinking I'll end up getting a tank from here. Hopefully I'll be able to pick it up from their shop and save on shipping. They've got nearly 350 standard RV potable tank sizes. The best values (in $/gal) are the 150 gallon and 60 gallon tanks. 40.25" x 32.5" x 28.5" and 32" x 23.75" x 20.5" respectively. 150 gallon is $360. 60 gallon is $153.
Take a look at their website and see if they've got a standard offering that'll fit. Even if it's not quite the dimensions you wanted, it'll be a lot easier and more durable than trying to build a water tank out of wood. Unless it's an outrageously large tank, I'd be willing to bet a custom size would be less than $1,000.
RV Water Tanks | RV Fresh Water Tanks | RV Potable Water Tanks
10-06-2015, 09:25 AM
Rated Cap: 40 Prisoners
10-06-2015, 01:29 PM
Just for the record...Black ABS tanks don't make the water taste like plastic and are naturally anti mold/fungal. They can also be fitted or repaired more easily than the white poly which cannot be glued successfully. Harder to find but make a world of difference in the water quality on the fresh water side.
I've found the blackwater side tastes funny no matter what it is in.
10-06-2015, 01:45 PM
Chassis: Blue Bird
Engine: ISC 8.3
Maybe the funny taste and the anti mold/fungal are effects of ethylene glycol contamination, rather than coming from the plastic?
Definitely right about ABS being solvent weldable whereas polyethylene isn't.
I had never heard of ABS having any inherent anti mold/fungal property. Did you make that part up? Anecdotal evidence does support the claim: every time I've cut open an ABS drain/sewer pipe, I've not found fungal growth inside. Didn't taste it, though.
10-06-2015, 02:11 PM
Valterra, who is one of the leading ABS tank makers claims "100% algae free" in there adverts. Of course, we all know advertising claims are always "100% true"...but...
10-06-2015, 02:15 PM
I'll keep that in mind.
Fortunately no blackwater on my bus so I won't mix them up... lol
10-06-2015, 02:57 PM
Chassis: Blue Bird
Engine: ISC 8.3
Algae-free makes sense. Algae requires light for photosynthesis; it won't grow in a dark place. An opaque ABS tank would surely have the advantage over translucent polyethylene in the algae department.
10-06-2015, 04:21 PM
Spoken like a science major! Had not thought of that angle.
11-21-2015, 01:46 PM
For what it's worth, fiberglass/plywood tanks are a very common thing to do in boats - for potable water, waste, and even diesel.
https://www.boats.com/reviews/build-your-own-fiberglass-potable-water-tank/
And obviously boats move and vibrate and have to deal with the shock load from hitting waves, etc.
This is also what I'm planning on doing for my grey and potable water tanks.
...At least, once we actually find a bus.
11-29-2015, 09:52 AM
Engine: Cat 3126e
Rated Cap: 28
I am planning on using a flexi tank www.ahoycaptain.com/plastimo_16657.html Used in boats as well. When you lift the floor up you should have ample space for the tank as well as to build a support around it.
11-29-2015, 10:33 AM
I'm considering those too. My concern is that by the time you buy two of those and build a frame to enclose them, you're probably at the cost of a plastic tank anyways...
11-29-2015, 11:04 AM
Engine: Cat 3126e
Rated Cap: 28
Ya at the end the cost will be some what the same. For myself they will work great as I will already building a frame around our bed so that we can place a false floor over it and plan to fit the flexi tanks on the sides between the bed and wall.
I also saw one used in a tiny house and it was hid underneath the couch @4:20 into the video is where he shows it. I also kicked around that idea but would rather have that space for other items.
