Old 11-04-2014, 01:24 PM   #1
Year: 95
Coachwork: Champion
Chassis: Ford E350
Engine: 7.5 L 8 Cyl Gasoline
Rated Cap: 18
Cut out new door
Hey everyone! I'm new to this forum as of today. I did do a quick search for "custom door" "cutout door" and some other things I thought would be relevant, but I don't think I'm able to find exactly what I'm looking for.
I'm in a band, and I'd like to install a door in the back of the bus for loading. The problem is... the bus doesn't have a back door! Only an emergency escape window! Has anyone had any luck cutting out a door frame and installing a custom one? It doesn't need to be a full sized door; it just needs to be big enough for a Bass drum and some cabs to slide into. So basically, a 4' x 4' hole in the rear that doesn't leak.
I've got a 25' Champion shuttle bus that I'm converting to a tour van. Thanks for any help or suggestions!!
IrreverentRyan is offline   Reply With Quote
Old 11-04-2014, 02:26 PM   #2
Re: Cut out new door
welcome
normally if they have a window and no door it is a rear pusher or a Crown with a trunk
Pictures?
Old 11-04-2014, 02:41 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
It's a shuttle van.
Old 11-04-2014, 03:01 PM   #4
Originally Posted by somewhereinusa
It's a shuttle van.
oopss..never read the info under the avatar sorry
so on that note anything is possible with a metal frame or wood that is bonded into/on the fiberglass;so it's sturdy
seems like fun project
thanks somewere
Old 11-04-2014, 06:36 PM   #5
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Welcome!
Champion owner here. Do a little bit of exploring for any framework back there. (Betting no). Its just the fiberglass shell + plywood inside-at least 4 1/2" up from the floor. I have a back door in mine-there is metal above it-but the wall could easily be altered.
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Replacing bus door with storm door??? leadsled01 Short-Bus Conversion Projects 13 03-18-2014 07:31 AM
Replacing the door with ext house door? jkronmiller Conversion General Discussions 2 06-10-2013 02:05 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 11:56 AM
Anyone ever used the bifold door as camper door ? RichardRWatson Conversion General Discussions 6 07-04-2007 09:27 PM
