Re: Cutting the roof & skinning the sides
I've yet to see a skoolie with a Cap. Gene's method was written for highway coaches which have slightly different skins on them but the Eagle frame and the Blue Bird frame have very similar tube dimensions (except Blue Bird apparently doesn't have the cross bracing that the Eagle has) Coach caps are a PITA. We've had both an Eagle and the current Blue Bird. Many coach self-converters have used Gene's method of a roof raise with no problems. Caps are big, huge bulky things that are metal and you replace with fiberglass (lots of $$$). Seems like everything on a highway coach involved lots of $$$. We simply don't have the time to raise the roof. We don't want to raise the roof. Like I said David & I are both short (5'8" and 5'4"). We like running the back roads and have done that for a few decades, enough to realize that we need to keep the overall height down. We don't want any "carbuncles" on the roof either. The only exception may be a low profile folding sat antenna (Winegard TRAV'LER DISH 1000 Multi-Satellite TV Antenna folds down to under 10" in height). No rooftop airs (noisy beasties) and no "luggage racks" on the roof (current Class C RV had one... we did a roof repair for the leaks). We are using a center aisle layout and David has already stood in the shower to make sure the height was okay.
