Old 04-24-2017, 05:03 PM   #1
Chassis: M94874
Engine: Cummins deisel 5.9
Question Dash Work - remove steering wheel?
Hi,
I need to work on the dash instruments but the steering wheel is blocking the dash board mounting screws. Is it hard to remove the steering wheel? And how is that done?
I also want to put in some insulation and extend the dash to the floor (wood maybe?).
Any advice is appreciated.
2000 Freightliner Blue Byrd, Cummins Deisel 5.9, 36 foot, front engine long nose.
Thanks,
Tim
timwilkerson is offline   Reply With Quote
Old 04-24-2017, 05:44 PM   #2
Robin97396's Avatar
How adventurous are you mechanically? It's really hard to recommend to do or not do things without knowing what you're comfortable with.
This is interesting because dashboards have been a common problem today, and I've been digging in my dashboard all morning. I didn't accomplish anything except for the education I gained.
Robin
Nobody's Business
Old 04-25-2017, 07:40 PM   #3
Coachwork: Thomas Saf-T-Liner
I've been working on my dash too. I was able to get a short screw driver behind my steering wheel. Most where stripped anyway so ended up using a grinder with a lot of careful grinding. Will be replacing with Robertson head screws. If the steering wheel is anything like a cars it will probably have a big nut in the middle then you would need a steering wheel puller to get it off.
Sent from my Nexus 6P using Tapatalk
nwarner2010 is offline   Reply With Quote
Old 04-25-2017, 08:01 PM   #4
Robin97396's Avatar
I don't take electrical stuff apart because it may never work again.
Robin
Nobody's Business
Old 04-25-2017, 08:16 PM   #5
I'm really hoping I can get mine back together and working with no hiccups. I took plenty of pictures to help me remember.
Old 04-25-2017, 08:32 PM   #6
Robin97396's Avatar
I'm one of those people that can put on a metallic watch and it will stop within 15 minutes. Weird things happen to electronics around me. I've learned to keep my hands off of electrical things as much as possible.
Robin
Nobody's Business
Old 12-05-2019, 01:45 PM   #7
PatrickBaptist's Avatar
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
I took the but off my wheel and it won't come off with a puller or even budge...
Any ideas?
04 IC flat nose on 3800 platform.
Thanks
PatrickBaptist is offline   Reply With Quote
steering wheel
