Old 03-11-2008, 08:46 PM   #1
Dayton Rims
I have 20 inch tube type tires on my bus. I would like to change to tubeless tires . Do they make a Dayton Rim inthe 22.5 tire type that will fit my orignal dayton spokes thanks for any help>>>>
colliervilledave is offline   Reply With Quote
Old 03-12-2008, 11:19 PM   #2
Engine: 7.3 diesel
Re: Dayton Rims
yes they do. A 22.5 dayton rim will go right on where your 20 are sitting now with no modifications. I've already switched mine and after doing so I did have to buy a couple spacer rings for the rears to get the wheel clamps to hold tight.
Old 03-13-2008, 05:57 PM   #3
Re: Dayton Rims
Thanks for the info, did you have a line on some of those rims, and the spacers,I could use four in a bad way.. I have to buy four rear tires and those 9.00x20 are hard to find and expensive..If I change over to the 22.5 tubeless , I can go thru work and get some 22.5 cheap, and those 20s are getting more expensive because there getting obsolete...trying to get the bus road worthy for the talladega race its a month away..
Old 03-14-2008, 01:02 PM   #4
Engine: 7.3 diesel
Re: Dayton Rims
Yes I had a really good connection at thee time and they no longer have any left. All I had to do was swap them before they went to a salvage yard of some sort. I was even lucky enough to even get a hold of a couple spares. Only thing I gotta do is figure out how and where to mount a spare on the bus. You shouldn't have to do anything more than just getting the 22.5 rims and tires.
Old 03-28-2008, 12:02 AM   #5
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Dayton Rims
hi what is up with the bolt pattern on the 20 inch rims? are ford the same as dodge as international as chevy ? my bus takes 10 lug nuts on the back and 5 on the front i too would like to update my 65 skoolie to 22.5 or whatever the new ones run thanks all timbuk
dayton wheel spacers silentbob Everything Else | General Skoolie Discussions 8 11-27-2019 02:34 PM
New tire installation on Dayton wheels PDBreske Mechanical and Drivetrains 9 07-29-2012 04:38 PM
22.5 Dayton wheels wanted jpatton1493 Classifieds | Buy, Sell, Swap 1 06-08-2010 09:29 PM
FREE 20" Dayton Wheels silentbob Classifieds | Buy, Sell, Swap 0 06-14-2009 11:15 AM
Dayton Rims colliervilledave Conversion General Discussions 2 01-11-2008 06:16 PM
