Old 02-18-2010, 04:45 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: DC generators....
Theoretically. As long as you could find a big enough inverter. I had considered this option as well for a generator. Get a 3hp engine and a high output alternator connected to an inverter. Probably a bit more to it, but I haven't looked into it very much yet.
Old 02-18-2010, 05:36 PM   #2
Coachwork: Ward Genesis
Engine: DT466/MT643
Originally Posted by Pied Typer
Okay, so I came across a really awesome deal on a generator... The catch is that it is a 24VDC generator rated at 100amps constant duty. The question is, if you have a 24VDC generator rated at 100 amps hooked up to appropriate 24VDC inverters does that mean you can get 10,000 +/- AC watts out of it?
I don't see how. 100 amps at 24 volts is only 2400 watts. Watts = amps x volts.
Jarlaxle
Old 02-18-2010, 05:42 PM   #3
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Good point, I didn't do the math. So a 12V 100amp alternator could only 'theoretically' put out up to 1200 watts. Not really worth building a 1200 watt generator. Now if you could get a 250 amp 24V alternator, that would be some great watts.
Old 02-18-2010, 11:12 PM   #4
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
No, amperage doesn't stay the same when converting. Think of it this way:
VOLTS is like pressure - more pressure means more flow
AMPS is like the size of a hose - bigger hose means more flow
WATTS is the actual amount of energy - more watts is more energy
Volts X Amps = Watts
12 X 100 = 1200
By changing a 12V source at 100 amps to 120V means that you will only get 10 amps. Of course 10 amps of 120V is a good amount of power. Of course this is all theoretical because there is always inefficiencies and energy loss due to heat.
Old 02-20-2010, 10:27 AM   #5
lapeer20m's Avatar
you'll be money ahead to spend the $1k and get a honda eu2000i generator. super quiet, super light, and up to 15 hours run time per gallon of fuel.
Let's talk about generators willhitch Conversion General Discussions 7 09-15-2014 03:56 PM
Onan generators chev49 Electrical, Charging and Solar 4 05-04-2012 05:43 AM
Generators Demonknight Conversion General Discussions 7 01-10-2008 04:00 AM
generators lapeer20m Everything Else | General Skoolie Discussions 8 03-30-2005 07:43 PM
generators lapeer20m Conversion General Discussions 1 08-18-2004 04:32 PM
