Old 08-25-2014, 08:51 PM   #31
Re: Deadbolt on front door?
Buy a chepo linear actuator (ebay) and set it up to bump the handle open when you turn the key in a keyed switch mounted on the side of your bus. If you just want to go getto. tie a rope around the handle, feed it over a pulley, extend it through a hole in the bus floor---pull to open
Old 08-25-2014, 10:35 PM   #32
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by BruceAlmighty
...I don't really want to replace the bus door, but I will have to if I can figure this out...
Building an Original Bluebird Two Piece Door into a One Piece Door
We have since replaced the round knob handle with a lever handle. It is much easier to open the door, in the winter, with an armload of groceries, with a lever rather than the knob. We also replaced the overly stiff and thick weather stripping we had originally used. It prevented the door from latching shut correctly. We replaced the weatherstripping with a softer "mushier" weatherstripping and the door latches correctly.
Kwikset Delta Satin Chrome Entry Lever Model # 405DL 26D CP Store SKU # 632905
We still need to skin the interior side of the door with PVC "wood" and make plexiglass panels to cover the single pane glass in the door. What this will do is create a thermal break and give us dual pane insulated glass. We get a lot of cold air off the steel & glass door in the wintertime. We will also add an accordian door for privacy. We have been using one on the bathroom and like it. Easy install and cut down.
Fulltime since 2006
the front door latch Zephod_beeblebrox2 Conversion General Discussions 5 11-22-2014 11:02 AM
Replacing the front door Zephod_beeblebrox2 Conversion General Discussions 11 10-27-2014 10:30 PM
NEED front door hinges millertyme Classifieds | Buy, Sell, Swap 1 09-20-2009 11:43 AM
Front door size busone Skoolie Conversion Projects 4 01-24-2006 12:40 AM
Bus front door question soused moose Conversion General Discussions 3 04-22-2004 08:32 PM
