Old 07-09-2009, 08:54 PM   #1
deck height concerns
So, I'm planning out my deck, and I was trying to decide if we want a 3' railing around the outside or a 1' one, or none at all. I would love to have the full 3 feet, but my concern is that the extra height would make the bus an little too high for ducking under trees and whatnot. I live in Portland, where there are lots of trees that hang over the roads. Has anyone had issues with decks causing their bus to not fit down streets?
Thanks
icnivad is offline   Reply With Quote
Old 07-09-2009, 09:16 PM   #2
TygerCub's Avatar
Engine: Detroit
Re: deck height concerns
Don't forget about fitting under bridges as well. I think the maximum height for any vehicle is 13 foot, or 13 ft. 6 in. Someone else can correct me if I'm wrong.
Why not go for a modular railing system? Or a fold-down rail? Either way, you can increase your height when needed, but still keep the vehicle streamline while going down the road.
Old 07-10-2009, 12:03 PM   #3
Papabear's Avatar
Coachwork: ward
Chassis: IH
With Smitty here. A hinged fold down railing would be your best bet. 36" high would be safe height for railing (for human occupancy). If your just going to put gear up there, a permanent 1' rail would work. One foot is just to short for people to be up there, as in race bus, etc.
"I've never been lost, but I been mighty confused for several days"
Papabear is offline   Reply With Quote
Old 07-10-2009, 09:00 PM   #4
Possably make the 1' railing as the storage rails for travel, but able to put extensions into it for the 36" railing when you plan to be on the deck.
Old 07-11-2009, 07:28 PM   #5
Coachwork: carpenter
Chassis: international
Engine: 7.3 diesel
I would try and keep the total height under 13' 6", as TygerCub said. This is sort of a standard maximum height. Eighteen wheeler trailers are 13' 6" high, so you would be able to go pretty much anywhere they do. There are vehicles that are over 13' 6" high, however they have to be cautious of bridges and low wires, and are subject to permits and restricted routes. That being said, there are some bridges that are under 13' 6".
My full size bus is 10' 3" at the crest of the roof, I'm sure most are comparable, so you may be alright, as long as you exercise caution when driving. A trucker's atlas will list low clearances on most major routes.
RyanS is offline   Reply With Quote
Do you have concerns? bus-bro Everything Else | General Skoolie Discussions 105 10-15-2009 02:08 AM
Bus Height oldog12 Everything Else | General Skoolie Discussions 6 11-02-2006 07:27 PM
School bus external height (Was: bizarre double-deck bus) lapeer20m Conversion General Discussions 2 02-20-2006 02:34 PM
Weight Concerns noahyay Conversion General Discussions 3 08-15-2005 03:34 PM
Height restrictions Jeff in AK Everything Else | General Skoolie Discussions 7 03-12-2005 04:35 PM
