Old 02-24-2006, 03:10 PM   #1
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
If you wanted to, you could tap in to your hot water line from a propane hot water heater, and just recirculate the water to the incoming line on your hot water tank. A check valve would keep it from flowing back into the holding tank through the cold water input line.
Eric von Kleist is offline   Reply With Quote
Old 02-24-2006, 10:00 PM   #2
Just thinking out loud. If you are not going to need the heat long you could have a big tank of water in or under the bus and heat it hot with the engine coolant while traveling. Then you could circulate that hot water through the radiant system. Of course if you are going to want a warm deck for many hours it would probably cool off to the point where it is worthelss.
busone is offline   Reply With Quote
Legality of a few Items - decks and seatbelts Seeria Titles, Insurance, Registration and Money Matters 2 05-12-2011 08:43 PM
Those of you with rear decks... busdriver_phil Conversion General Discussions 5 04-30-2010 09:32 AM
Roof decks? thesaltydog24 Conversion General Discussions 7 11-04-2009 05:51 PM
Rooftop Decks arfisher83 Conversion General Discussions 9 08-13-2009 03:05 PM
Radiant Floor Heating oldog12 Conversion General Discussions 8 08-24-2006 01:05 PM
