Old 04-26-2015, 09:05 PM   #11
crazycal's Avatar
Originally Posted by The-Breeze View Post
Not having a ramp makes it easier.....my first thought was a ramp, since I assumed you wanted the back to open to bring in something BIG.
Personally, if I was to go thru the trouble of cutting into the back I would definitely have it so I could just open it up from the top, preferably with hydraulic "thingies" (sorry, I'm just a woman who doesn't know all them fancy names for things), so it doesn't just open and knock some sense into me and have me a nice back porch (with a canopy for rainy days).
Also, having a nice level spot where you can work on whatever it is you plan to bring on board, without having to kneel down and/or bend over. I picture having the "new door" sheet metaled for ease in cleaning and walking on and of course with rubber sealing all around for creating an air type opening and protection for myself while it's open.
Darn, sure wish we had the health and time to do something like that on our bus.
Sorry I don't have pictures to show you what I mean, but it seems pretty straightforward.
Girls can play too but being a guy, I am a visual animal. You can't tell me, you have to show me.
I'm hungry!
You Gotta Let Me Fly
Old 04-26-2015, 09:18 PM   #12
I'm way, way, way past the age of showing anything anymore. Either that or the fact I cut back on my alcohol consumption!
Too bad too, it use to be lots of fun. ( I )
The-Breeze is offline   Reply With Quote
Old 04-26-2015, 09:51 PM   #13
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
... preferably with hydraulic "thingies" (sorry, I'm just a woman who doesn't know all them fancy names for things)...
Don't sell yourself short. I know LOTS of guys who don't know the name for them either
Am I correct in thinking that you mean "rams" ?
Hank's P-O-S is offline   Reply With Quote
Old 04-26-2015, 10:51 PM   #14
PDBreske's Avatar
Rated Cap: 1
I will think on this. I may already have an idea, but I don't know if this will be beyond the level of your building skills or beyond the level of your desire to have something different.
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Old 04-27-2015, 08:10 AM   #15
The best source for what I THINK you're describing is "trunk hinges" off eBay. I've used this exact unit in another project and it held a fairly heavy (80lbs) canopy upright in a stiff wind:
BMW E46 99 05 Steel Blue Trunk Hinges Mounts Shocks Joints Left Right Set | eBay
These trunk hinges use a hydraulic cylinder but don't search with that as the term - you're more likely to find bottle jacks and hydraulic equipment that way. In the auto industry they're referred to as "gas struts" and you'll find a million options with that as your search term.
Usually they're threaded at one or both ends, and you can get a variety of attachments. The standard setup has a ring end that bolts onto a mounting bracket, and the other end has a ball socket with a quick-release clip. That goes to another mounting bracket that has a ball to go into the socket. You can get these in all shapes and layouts, right angles, etc.
They're also available in a huge array of lengths and strengths.
Or did you want something else?
taskswap is offline   Reply With Quote
Old 04-27-2015, 10:04 PM   #16
I was thinking more on the lines of what is on vans & suvs that open & close the rear door. You know like when you lift open the door you only have to get it so far and then this hydraulic "lifter/thingie" takes over and vice/versa when closing. Or is something like that only good when the door is hinged at the top and not on the bottom?
Old 04-28-2015, 07:02 AM   #17
Do you mean the electrically-actuated ones? They're functionally identical to the brackets I posted above, they just add an electric actuator to "assist" with the process. Search for "power liftgate".
Power Liftgate Actuator Left Fits 10 15 Chevrolet Equinox | eBay
2007 Chevrolet Tahoe Power Lift Gate Motor | eBay
Note: these parts are expensive and not exactly plug-and-play. Most of them are designed to lift very heavy weights while still being a compact package themselves. The brackets they attach to can be under hundreds of pounds of stress. You need strong attach points and for the cylinders/struts to be in exactly the right spots. It's easy to do these wrong.
Old 04-28-2015, 01:47 PM   #18
crazycal's Avatar
You guys and gal aren't working hard enough. Don't make me give myself the prize money.
So far I have found this. Fast forward to 2:15.
Found it here.
http://www.skoolie.net/forums/f11/ca...-bus-3422.html
Or this found here. new toy hauler - ATVConnection.com ATV Enthusiast Community
http://i276.photobucket.com/albums/k...331Bus0003.jpg
I'm hungry!
Old 04-28-2015, 01:52 PM   #19
crazycal's Avatar
http://blogs.courant.com/autoracing/Short%20bus.jpg
I'm hungry!
Old 04-28-2015, 02:51 PM   #20
crazycal's Avatar
This is what I had in mind.
School Bus to RV - Yesterday's Tractors
I'm hungry!
