Old 03-28-2019, 03:53 AM   #1
Detroit 6v92
Should I run away from buses with this engine? It is a two stroke....is it very fuel efficient? Easy to repair/overhaul? I am sure that all of the smog laws would prohibit it if it were a newly released engine. And it is at least 600 pounds heavier than some of then newer engines.
pengyou is offline   Reply With Quote
Old 03-28-2019, 06:08 AM   #2
Engine: 345 international V-8
Good engine, easy to repair, often misunderstoud. Not many modern mechanics have worked on them. They tend to be noisy. Nicknamed "screaming jimmy". I like them but not for everyone.
Old 03-28-2019, 06:11 AM   #3
Noisy...probably because they are 2 stroke
Old 03-28-2019, 06:22 AM   #4
Engine: TE 444
Rated Cap: 12
Good engine, just don't overheat it, 2 stroke diesel Detroit's are not like 2 stroke gas engines, they do not pull the charge through the crankcase and have exhaust valves
Old 03-28-2019, 06:26 AM   #5
Buses are noisy and inefficient. Embrace it.
Roll Your Own Build Thread
Old 03-28-2019, 06:33 AM   #6
It has gone through my mind to stick a 6V-71 in the shorty.... with turbo up to 300hp.
Old 03-28-2019, 06:37 AM   #7
If you do can I PLEASE watch? I want a 2 stroke school bus BAD.
Old 03-28-2019, 07:18 AM   #8
Year: 1980
Coachwork: Crown Coach
Engine: Detroit 671T
Personally I would prefer this engine to a lot of the newer stuff, very easy to work on once you understand how they work, all mechanical, super durable and resilient (as long as you don't overheat it as previously mentioned) parts are readily available nationwide. Sounds so so sweet, like a steel symphony.
What kind of a bus did you find it in?
I would love to see this! Found a thread on another site where a guy swapped a 671T into an old square crew cab Ford F350, was a crazy build, didn't fit under the hood, weighed as much as the rest of the truck. Just Awesome. I am getting a Crown and its like 75% for the Detroit.
Willie_McCoy is offline   Reply With Quote
Old 03-28-2019, 07:29 AM   #9
I guess I will have to post some pics on the shorty when i get around to doing something with it. My wife is ready now to start on it....and I have been looking at engines for sale slowly....
You are certainly welcome to come up here and watch, might put you to work on it too.
Old 03-28-2019, 08:04 AM   #10
If she had a set of wings, man, I know she would fly....
