Old 09-29-2005, 11:15 AM   #1
AK-Brando's Avatar
Diesel Stove?
Has anybody tried installing a diesel stove? We use these all the time on our commercial fishing boats up here in Alaska. They work great as heaters and pretty good at cooking and baking too. On hot days we would shut the stove down and put a portable propane stove on top for cooking. I was thinking of installing one and not having to deal with installing propane at all.
This is the model I am looking at (unless eBay provides something else). I have found it new at Boat Owners World http://www.boatownersworld.com/dicki...ns_cookers.htm or direct from Dickinson Marine http://www.dickinsonmarine.com/shop5...p?catalogid=34
I already have a diesel engine heater installed and plumbed to the main tank, so I think I could just tap off that line for the diesel stove.
Brian
'91 Thomas/Ford B700 7.8L Diesel 5-speed (seats removed)
My Bus Pics
My Bus Blog (hasn't been updated in a LONG time)
AK-Brando is offline   Reply With Quote
Old 09-29-2005, 11:17 PM   #2
WOW! Those are nice. I would love to do one of those, and my wife would probably like it even better. Seems like it should work great in a bus. Some of the guys with Webasto diesel fired water heaters install a smaller diesel tank and use the off road fuel for them. You can get the tanks cheap from any place that deals with reefer trailers. That way you don't have to pay road tax to cook and heat. Of course AK has a really cheap fuel tax so it may not be worth it.
busone is offline   Reply With Quote
Old 09-30-2005, 12:04 AM   #3
AK-Brando's Avatar
Well they supposedly only burn about 1 1/4 to 1 1/2 gallons of diesel in a 24 hour period. On our fishing boats we would run them all summer, unless it got really hot or we were leaving the boat unattended. I know these can take some abuse, and even high winds didn't seem to bother them too much as long as you run the combustion assist fan. I've personally seen 90 kt winds while at anchor running one of these - although we were in a lee, so we probably only had 30-40 across the stack.
Brian
My Bus Pics
Old 09-30-2005, 11:13 PM   #4
Wow, they are really easy on the fuel. I guess for the little bit they burn it would probably not be worth the trouble/cost for a seperate tank. If I can afford one I will get one. If I can avoid propane I will.
Old 10-04-2005, 11:09 PM   #5
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
diesel stove
Most of the drillers I work with have stoves in their drill rigs, made by their shop. Basically a modification of a wood stove design. Steel tubing approx. 20" dia +/-, a door with a air intake/flue in the front, welded shut at the other end and a stove-pipe at the top-back. A set of legs, a sheet of metal bent into a ] shape welded on top for a cooking surface, and you're in business. A fine-threaded valve drips fuel onto sand/lava rock for combustion. I'd add a thermocouple and 12volt solenoid/valve to shut the flow off if the temp goes way low, to avoid a messy spill! A lot of heat for little money. If anyone builds one, post pics and details!!
If it isn't grown, it has to be mined
http://weathersticker.wunderground.c...Winnemucca.gif
elkoskoolie is offline   Reply With Quote
Old 10-06-2005, 09:50 AM   #6
lapeer20m's Avatar
I've tried that type of waste oil burner before...mother earth news did an article on it some time ago...
i've yet to find anyone who actually got it to work safely. The problem is that as the oil heats up, it starts running faster and faster. What was a slow drip becomes a stream of oil. In my R&D I had 6 foot flames shooting out the top of my "stove" (it was really a 55 gallon drum)
but this sort of homemade device is a completely different animal from what the original post was about.
I think the commercially available diesel stove is an excellent idea. It's so much safer than propane, and the added benifit of sucking the fuel out of the stock diesel tank is very attractive.
Old 10-06-2005, 09:04 PM   #7
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
If only it didn't cost almost as much as my bus .....
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 10-06-2005, 11:38 PM   #8
I wonder if one could be had from a military auction? I suppose the hassle with an auction might make the price worth it.
Old 10-07-2005, 12:00 AM   #9
AK-Brando's Avatar
I've been watching eBay for one, but so far haven't seen very many. I'm going to check the local marinas to see if they have any used ones this spring.
Brian
My Bus Pics
Rocket stove magic_bus Alternative Fuels | Electric, Propane, Wood Gasification, etc. 39 06-18-2015 07:48 AM
First Real Question, Second post. Diesel Stove… kc_4_jc Conversion General Discussions 1 02-24-2011 11:47 PM
Wood Stove for Bus? Seeria Heating, Cooling and Appliances 0 12-15-2010 02:56 PM
electric stove? Mulelover Alternative Fuels | Electric, Propane, Wood Gasification, etc. 8 01-24-2010 08:45 AM
converting a stove. Steve Conversion General Discussions 1 06-02-2006 09:07 PM
