Old 10-22-2018, 10:39 AM   #21
Rogue1bus's Avatar
My RE Amtran is only 30’ long, so the wheel base is shorter and it’s surprisingly maneuverable and the ground clearance is good, only spot you have to carefully watch is the steps in the front passenger side.
Rogue1bus is offline   Reply With Quote
Old 10-24-2018, 12:48 PM   #22
Coachwork: Freightliner Thomas
Engine: 5.9L Cummins Diesel
Rated Cap: 71
In case it's helpful, here's a related thread with some good insights:
http://www.skoolie.net/forums/f13/pu...ain-21989.html
olives is offline   Reply With Quote
Old 10-27-2018, 06:32 PM   #23
G Dub's Avatar
Year: TBD
Coachwork: TBD (Bluebird?)
Chassis: TBD
Engine: Will be diesel
Rated Cap: As big as possible
Originally Posted by Mekanic View Post
To G dub i’d Maybe switch to air ride front and rear but NEVER give up my straight axles.
(I did swap my Ford to a freightliner air ride on the rear.). Best time/money investment there is on large truck.
Air ride is definitely on my mind, big time. In fact, I'm committed to it.
But I'm curious, why do you prefer straight axles to independent suspension (IS)? Is there something about a bus that is different than other vehicles when it comes to a smoother ride with IS over a straight axle? I would think that it would keep the swaying down to a minimum (if there is such a thing).
Thanks
Driven to get skooled.
www.Zomnibus.life
G Dub is offline   Reply With Quote
