Old 07-09-2011, 03:31 PM   #1
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: Disconnecting School Bus Wiring
Have a look at thedevice/switch at the emergency exit doors. It may be that a circuit was closed (meaning current could flow) when the door was closed, so simply unplugging the wires would leave the circuit open. You may need to jumper or otherwise connect two sets of wires. If there is a single wire for the switch, the switch may have made a connection to ground, so it may be a matter of grounding the wire. Basically what Rich said. Please use all safety precautions when testing these theories.
Bus conversion/info here
SeanF is offline   Reply With Quote
Can anyone help with re-wiring in NYC? sebjaram Conversion General Discussions 1 09-09-2014 12:40 PM
1991 Thomas School Bus ~ Wiring Diagram needed. roadfamily6now Skoolie Conversion Projects 2 05-21-2012 01:55 PM
Disconnecting the emergency exit "Kill Switchs" dunnwright Conversion General Discussions 4 11-13-2010 09:12 PM
Wiring Diagram 1981 IH school bus jerhutch Conversion General Discussions 4 08-20-2008 10:45 AM
Back to School: School Bus Safety (Video) Steve School Bus News 0 08-22-2004 04:00 PM
