Old 07-19-2010, 01:55 PM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Do you get water coming in thru your vents?
For those who have used HVAC indoor louvered vents for various purposes on the outside of your bus, I can't help but wonder if water gets in there? Surely during a good storm if you're driving down the road, the wind must whip a certain amount of rain into the bus through those vents, right? Here is an example of what I'm talking about:
I'm going to need to vent my battery compartment, which may actually end up being inside the bus, so I'm wondering how these vents have worked out related to water coming in.
Who has had experience with this?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-19-2010, 06:53 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Do you get water coming in thru your vents?
On the Class C... I have one of those on the back section of the refrigerator, 2 on the generator, 1 venting the portable gastank for the generator and 1 small one venting the converter. Only thing different is I have made screens to keep the creepy crawlies out. No water problems a little damp at times when the rain is blowing almost horizontally. And it rains a lot in the SW Appalachian Mountains... not so much here in NM.
Fulltime since 2006
Old 07-20-2010, 02:26 PM   #3
Rated Cap: 89
Originally Posted by Smitty
... return air vents. I'd venture to say the only way either would not leak (on a vertical surface), were if they never saw rain
Smitty
Mine are return air vents (does NOT have a shut off or damper). I've had them installed on the Class C since 2006. During that time we were in the RV (full-time) in NC, GA, NC, FL, GA, FL, NC, TN, NC, NM, TX and now back in NM. While it doesn't rain much in NM, it did rain a lot while in Corpus Christi TX and let's face it, drought or no drought, it flat rains a lot in GA, NC, & TN. I mean honestly... there was emerald green MOSS growing in the window ledges of the skoolie when we left NC (it was brown by the time we hit the TX state line). Yes we have gotten tiny amounts of rain inside the openings. But less than if you walked in to the RV with wet feet from the rain. And I have driven in the rain (raining so hard we had to pull over, we couldn't see to drive). Driven on interstates with semi-trucks passing me. Not a problem. I figure you will probably get more water damage from accidentally leaving a window slightly open than you will from one of these vents. But I could be wrong... it's hot and I'm getting cranky.
Fulltime since 2006
Old 07-20-2010, 08:29 PM   #4
Rated Cap: 89
... How hard would it be to add a shroud over them? Like an awning, but more like a large dryer vent cap....more vertical than horizontal.
lol....you can be as cranky as ya like....I don't have to live with ya
Smitty
The "shroud" would have to be pretty big. We are ventilating a refrigerator stacked on top of a freezer (that's a huge heat build up in the summer). We keep a fan blowing air thru the cabinetry and up to the rooftop vent. It's 100 degrees inside the RV and my freezer (on the warmest setting) is -6.2F. I need to be someplace cooler in the summer.
The generator is in a metal lined "box". It needs a fair amount of air flow too.
And you would be cranky too if you were sitting in 100+ degree heat and the water in your fresh tank was too hot to take a "cool" shower! OMG IT'S SOOO HOT! And it doesn't cool off until after midnight! Of course it IS a dry heat... like a convection oven... I gotta go suck up some AC at Wally World!
Fulltime since 2006
Old 07-22-2010, 12:06 PM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
Hmmm... I may be better served by venting out of the floor of the bus rather than the sides. Maybe have a sort of p-trap type thing so that it is harder for water to find it's way up into the bus. I'm thinking of having a small exhaust fan that will run when the batteries are charging. Is that going overboard?
Gallery:
Conversion Thread:
Old 07-22-2010, 10:33 PM   #6
Rated Cap: 89
You have a breeze??? The only "breeze" we get is just before a rainstorm and then it's more like a gale... with dust... and everything that used to be in the neighbours yard! We now know why all the yards around here have walls!!
Fulltime since 2006
California Busses coming Up For Sale Stu & Filo. T Conversion General Discussions 3 10-23-2014 09:29 PM
New Cummins engine coming frank-id Everything Else | General Skoolie Discussions 1 10-13-2013 07:40 PM
Tomorrow is the day, The BOV is coming home! kc_4_jc Conversion General Discussions 5 02-22-2011 10:41 PM
Indicator light coming on cousin eddie Conversion General Discussions 0 05-27-2009 11:29 PM
I'm sure the sales man seen me coming from a mile away. Train-train Conversion General Discussions 5 09-15-2007 09:01 AM
