Old 07-19-2018, 11:43 AM   #1
Engine: Cummings 6 cylinder diesel
Does anybody know the interior surface area in Sq ft of a 2000 series bluebird?
So I'm leaving Florida for Pennsylvania in a couple of days and while I'm down here I want to pick up some cypress planks for the interior of my bus. Does anybody know the total square footage of the inside of a 2000 series blue bird bus including floor walls and ceiling?
Anthrobus is offline   Reply With Quote
Old 07-19-2018, 12:19 PM   #2
It's roughly 26.5 around the inside of a bus. Multiply that by your build length for your square footage. By bus has 32' of build space, or 848sf.
Old 07-19-2018, 04:15 PM   #3
What kind of math is that you are using?
L x W usually amounts to sq/ft no?
Your bus must be the size of three buses according to you.
Mine is about 30x 8 or 240 sq. ft.
What are you talking about?
Old 07-19-2018, 04:26 PM   #4
His post was only 2 sentences, I guess you only read the first. Nor did you read and comprehend my answer.
Old 07-19-2018, 04:27 PM   #5
Chassis: All American RE
Engine: 8.3TA
OP is asking for the sq ft of the floor, walls and ceiling. Marc used the circumference of the interior and multiplied it by the length of useable space. I did not check his math, however he was answering the original question, awkwards as it was phrased.
GaryC
Gustav is offline   Reply With Quote
Old 07-19-2018, 04:31 PM   #6
Of course adjust your numbers for windows and doors.
Old 07-20-2018, 09:58 PM   #7
Sorry I did read it wrong thinking only floor sq footage, not counting walls and ceiling also.
Still don't understand your 26.5 around the inside measurement.
I didn't know going from Florida to Pennsylvania for cypress wood was possible. Maybe English isn't my first language.
Thanks Gustav for clarification also,
Old 07-20-2018, 10:06 PM   #8
In my bus, if you take the tape measure and start at the bottom of one wall and measure that wall, around the ceilng, down the other wall, and across the floor is 26.5'. Multiply that by your usable length and thats your total square footage of the "shell". Subtract 50-75sf for windows.
