Old 04-19-2016, 08:06 PM   #11
Chassis: International S3800
Originally Posted by Docsgsxr View Post
Tango, how big of a bat bank and alternator are you suggesting?
a 220 amp alternator should do fine for a 12000 BTU minisplit.. ive never seen mine pull any more than 1100 watts or so and thats when it blasts.. most times it is around 750 or less...
if you are going to idle alot then maybe an 8D battery? install a battery isolater so that your main batteries wont discharge if you are running your A/C with the engine off..
Old 04-19-2016, 08:27 PM   #12
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Thanks CK. I think I will do that with the alternator, my battery bank changed, I have 6-6v 305 Ah crown batteries on order. I do have a little hyundai inverter/generator however, think that would power it ok while I drove? I could always get an external tank for it.
My build thread - viewtopic.php?f=9&t=467197
Old 04-19-2016, 09:16 PM   #13
I have an 250 amp alt I am installing, with a yet to be determined inverter and three 150 AH batteries. I still need to do a load analysis before I commit to the inverter but whatever the combo, it should be enough for my 12 volt fridge/freezer and 8000 BTU A/C......I hope.
Old 04-20-2016, 01:11 AM   #14
Chassis: TC2000 RE
Engine: 8.3l Cummins
If you get a chance, could you provide some details about the size and setup of your batteries, and the amp draw/duty cycle of the air conditioner? What kind of run times are you expecting maybe?
Originally Posted by somewhereinusa View Post
I haven't done anything other than to test to see if it works. It does. Inverter mini split,3000W sine inverter running off of my small house bank, charged from bus alternator.
aaronsb is offline   Reply With Quote
Old 04-20-2016, 05:47 AM   #15
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
"reeeeeeeeealy long cord"
i called the factory that makes the cord you speak of. turns out its the same cord that powers up my teleporter..... i've had one on back order for years, horrible customer service!
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 04-20-2016, 12:25 PM   #16
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Our setup will be very simple:
underbelly inverter generator while driving to run A/C, fridge, and a couple of outlets for tablet/phone charging. Then, once we reach our destination, plugin to park power. We're only planning to travel to parks that have RV outlets, and shower facilities, anyway ;)
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 04-20-2016, 12:51 PM   #17
Robin97396's Avatar
Ha, everybody knows teleporting takes two cords.
You're talking about a special duty cord when you're using the time machine.
Old 04-20-2016, 02:02 PM   #18
Coachwork: Ward
Pfft!
My frequency fluid activated warp-driven space-time machine (copyright/patent pending) is DA BOMB!
Also, no cables required...
Old 04-20-2016, 04:00 PM   #19
Docsgsxr's Avatar
Okay, get back on topic please. Take your Star Trek fun to a Star Trek forum......
Old 04-20-2016, 04:12 PM   #20
Coachwork: Ward
You're no fun! Right, but no fun.
So we mentioned generators, alternators and battery banks. Question: would you upgrade the alt., or custom mount a second one?
Sent from my Nexus 6 using Tapatalk
