Old 05-03-2010, 09:41 PM   #1
Does this combo exist?
Does anyone know if a bus was made that has this combo:
Transit/RE bus
35' in length
78" "higher ceiling" clearance
Wheelchair lift with the door at the side of the bus JUST IN FRONT of the engine... (not in the middle where I keep seeing them).
We've put together a floor plan with all of our wants laid out... but so far what we've found is that the RE buses seem to have that handicapped access door in the middle on the side... where we want it towards the BACK on the side.
(We're at a cross-roads between a RE and a mini-garage in the back of the bus to carry a few motorcycles... and from everything I've read, an FE bus isn't all that much fun to listen to for hours on end...)
Halitosis
Halitosis is offline   Reply With Quote
Old 05-04-2010, 12:56 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Does this combo exist?
I have never seen a rear engine bus less than 40', except maybe a city transit bus.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 05-04-2010, 06:30 PM   #3
busdriver_phil's Avatar
Coachwork: AmTran RE
72 passenger rear-engine school buses are usually 36'. Some REs were ordered as 13-row bodies with 12 rows of seats (mine is like this), so you get a 38' body. They were available down to 60 passenger, which would be closer to 32-33 feet.
City transit buses are/were available from most manufacturers going back to the 50s and 60s in 30, 35, and 40 ft lengths.
Headroom is usually 73-74" standard, 77-78" optional.
Lift doors were usually placed in the middle to keep the wheelchair positions near the middle. Wheelchair passengers need a clear path to the emergency door that is wider than a standard aisle, so they tried to keep them as close to the emergency doors as possible.
Many REs have additional emergency exits on the right side, which are usually located slightly to the rear (and narrower than a lift door). However, most are still positioned in front of the rear axle. The specific design you want might have been ordered at some point, but it would be very rare.
My advice: Find a good RE with everything else you want, and add the door where you need it.
The conversion of Miss Euphegenia, a 1999 AmTran RE: https://www.skoolie.net/forum/viewtopic.php?f=9&t=5704
Toilet shower combo bapos Plumbing, Water and Waste 16 10-04-2014 03:01 PM
24" Vanity combo $39 lornaschinske Everything Else | General Skoolie Discussions 0 04-23-2012 01:38 PM
Heat/Air Conditioner combo BUSBOZO Conversion General Discussions 6 01-03-2010 08:05 AM
Does a Gold Paint Exist? wdbowers Conversion General Discussions 0 10-08-2008 09:55 PM
The master cylinder that doesnt exist! - GMC 1 3/4" bor Steve Everything Else | General Skoolie Discussions 9 11-27-2006 06:46 PM
