Old 09-04-2013, 05:22 AM   #1
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Dog-Nose? Flat-Nose? Conventional? Pusher?
As it becomes obvious to me that my current Pace Arrow will suffer the same fate of a failed roof as my 28-footer, I contemplate using the two for parts to build a bus when I have the time and money to do so. However, on reflection, there were some things about the Ford-chassis Blue Bird I previously owned that I found I didn't particularly care for...
1) - The Lucas-Girling hydraulic brake system. JUNK. Absolute, unadulterated, JUNK. Are they still built this way, and if not, when did they stop? While I have no real preference (my understanding is that CDL is not required for motorhomes, even if they have air brakes), when I go bus shopping, I will only buy a Ford-chassis with air-brakes.
2) - The utter inaccessibility of the engine, due to the conventional-type hood arrangement. Therefore, again, while I have no real preference, my criteria for a dog-nose is a one-piece tilt-forward nose, like a semi.
3) - The standard height roof and short rear door through which I routinely entered and exited. I know these things are designed for kids, who generally aren't as tall as adults, but I remember reading that some buses came factory with a higher roof, and I have noticed that many newer ones have a taller rear door, as well as additional side doors. Do only certain manufacturers build this way?
I would like to hear from others on what manufacturers and chassis I should stay away from, as well as any thoughts on the pros and cons of flat-nose buses vs dog-noses, and conventional powertrain/drivetrain layouts, vs pushers.
"Cheese Wagon" <anomaly.va@gmail.com>
Former owner - 1989 Ford B700 64-pass Blue Bird (Rest In Peace, Cheese Wagon)
Old 09-04-2013, 09:48 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Dog-Nose? Flat-Nose? Conventional? Pusher?
1) - The Lucas-Girling hydraulic brake system. JUNK. Absolute, unadulterated, JUNK. Are they still built this way, and if not, when did they stop? While I have no real preference (my understanding is that CDL is not required for motorhomes, even if they have air brakes), when I go bus shopping, if it is a Ford-chassis, it will be air-brake ONLY.
How old was that thing, I don't think Ford has done this for quite some time.
Here again, I think that newer might be better and more likely to have a tilt hood. I think you will also find that the tilt hood may not help all that much since much of the engine may be back further than the firewall with an engine cover inside. Those that have them can better address that. I myself like a Bluebird pusher, the whole back end opens, I believe Thomas is built that way also. I have seen IC's that only had a smaller door in the middle that opened. I can stand on the ground and work on pretty much anything and don't even have to crawl over the tires. The only real things in the way are things I put there.
Thomas and Bluebird both had three different roof heights, I don't know about the others. You just have to look around. I don't know what year, but both of those manufacturers have quit offering anything but the tall ones. I think that the side door exit and placement is probably by individual school corporation and or state requirements.
THIS IS ONLY MY OPINION.
Pros to RE(pusher)
noise is "back there" I can hardly hear mine running.
more interior room compared to overall length of bus
no long driveshaft taking up valuable under bus space
better ride
easier to work on
better overall driver viewing area
wider straight entry steps
no engine cowl to have to get around to get to driver seat.
Pros to conventional
looks like a school bus ???
Dick
Old 09-04-2013, 10:04 AM   #3
wmkbailey's Avatar
Engine: 3126
Ditto what Somewhere said.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 09-04-2013, 06:39 PM   #4
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
It was an '89 model. I drove a '96 F650 box truck that had this junk on it as well, and I have not heard of hydraulic-brake Fords being built any other way. Hydro-boost, I can understand to a degree because of diesel engine options, but why not just have a simple engine-driven vacuum pump? :P
Old 09-08-2013, 02:29 AM   #5
Chassis: All American RE
Engine: Cummins 8.3
Rated Cap: 90
I'd personally prefer the pusher for the reasons mentioned above, but I can think of two other commonly referenced pros of the front engine configurations: they are more capable off road, due to more ground clearance and shorter wheelbase, and they drive pretty much like any other truck, while the feeling of being so far in front of the front axle(as in the long pushers and especially coaches)is hard for some people to get used to.
My build:
http://www.skoolie.net/forums/showthread.php?t=10085
JDecker is offline   Reply With Quote
Old 09-09-2013, 12:34 PM   #6
Diesel Dan's Avatar
Engine: DT466/AT545
One advantage of a front engine bus that hasn't been mentioned here is the capacity for hauling cargo. I deliberately left my center aisle completely unobstructed front to back (except for a door that separates a rear utility/bath room, but can be opened). So I can load very long pieces of material into the bus. For instance, I am about to install gutters on my house, and will be able to easily load the gutters into my bus. Also, I can fit 8x4 sheets of plywood, drywall, insulation, or whatever, through the rear door. Other people have modified the rear end of their front-engine buses to enable the whole rear section to fold down as a ramp so a vehicle can be loaded in there.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 09-09-2013, 02:52 PM   #7
Originally Posted by Diesel Dan
One advantage of a front engine bus that hasn't been mentioned here is the capacity for hauling cargo. I deliberately left my center aisle completely unobstructed front to back (except for a door that separates a rear utility/bath room, but can be opened). So I can load very long pieces of material into the bus. For instance, I am about to install gutters in my house, and will be able to easily load the gutters into my bus. Also, I can fit 8x4 sheets of plywood, drywall, insulation, or whatever, through the rear door. Other people have modified the rear end of their front-engine buses to enable the whole rear section to fold down as a ramp so a vehicle can be loaded in there.
X2 it is nice to have 20/24 foot pcs of metal instead of cutting it down
Old 09-09-2013, 07:04 PM   #8
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Well, they are, after all, medium duty dog-nose/cabover truck chassis at their basics...
Old 09-09-2013, 11:38 PM   #9
syke's Avatar
Pusher.... just sayin.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 09-15-2013, 12:40 PM   #10
Skunky Bus's Avatar
Chassis: Dodge S-600
Engine: 360 V8
Pros to RE(pusher)
better ride
easier to work on
One aspect of the dog-nose that may be a factor for some folks: driving position. The ones I've sat in are enough like my Class C that I'd have to take a tape measure to notice differences in seat height and steering-wheel angle. The flat-nose models I've seen (especially older models) have a more horizontal steering wheel and lower instrument panel. I'm sure I wouldn't like that as much. If I were going for a flat-nose I'd probably want a pusher for the reasons Dick/Somewhere mentioned, esp. the dang doghouse on FE bodies is bigger than my Class C and in the way of my 3-1/2 feet of legs. Could be that some flat-noses have steering-wheel angle more to my liking.
Dick
I like that school-bus look. Some folks hate it.
Any action for which there is no logical explanation will be deemed "company policy."
- Akvol's Second Law of the Corporation
Skunky Bus is offline   Reply With Quote
Old 09-15-2013, 12:48 PM   #11
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
As do I... Guess it's because I grew up with conventional dog-nose gassers ... Loved the look of my old '89 Ford B-series... Too bad I had to get rid of her. Found out it had a brand-new 429 Jasper engine with probably <10k on it. Probably for the better though... It had the crappy Lucas-Girling brakes...
Old 09-15-2013, 03:06 PM   #12
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
That's sucks about your bus having to be gotten rid of. That would be a nice motor to put in a lot of things if your a Ford guy? Things happen for a reason....do as you did move on to better things.
Old 09-15-2013, 03:14 PM   #13
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Yeah, kinda thinking about a flat-nose, pusher or not. I really dig the old dog-nose gassers but I suspect that being hard to find will be the least of my problems at this point, and I kinda like the better maneuverability of having the steering axle under/behind you...
Old 09-15-2013, 06:06 PM   #14
bapos's Avatar
I agree on all counts. I think if I had to do it all over again I would do a BB flat nose rear engine just do to the space.
Old 09-15-2013, 08:32 PM   #15
Coachwork: Ward Genesis
Engine: DT466/MT643
IIRC, Ford used the L-G brakes until the cabs changed for 1999. Not just Ford, either: some Freightliners also did...all I have seen were smaller shuttle bus/delivery truck type chassis. Good idea, but the reality of it SUCKED!
Regarding the tilt-front, I think all Internationals since the early 70's had that...so did some Fords and GMC's. (My B700 had a tilt hood.)
Jarlaxle
Old 09-15-2013, 08:33 PM   #16
Elliot Naess's Avatar
Engine: 5,9 Cummins
I urge anyone to avoid "forward control" buses. Also known as "flat nose, front engine". That is, the engine inside right next to the driver. I have one, and it is pretty much impossible to do any repair on the left side of the engine -- and that's where much of the stuff that needs repair is located.
So pusher in general, or conventional if you must have a rear cargo opening.
Elliot
Old 09-16-2013, 07:01 AM   #17
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Yes, I remember discussing this with other Ford-chassis owners in my former (and extensive) stint here... I find it strange that other B700s, B600s, and B800s, all seemed to have no rhyme or reason as to conventional-hood style versus a tilt-nose. I saw older B600s that had a tilt-nose, and I saw newer B700s that had a conventional hood.
Personally, I think I just had a battle-scarred bus with a nose transplant from an older F-600/700/800 truck with the conventional hood. It didn't appear to have ever been wrecked though. The odometer read 057xxx, (and yes, it was a six-digit odo) but I believe more like 1,050,xxx - Alluding mainly to the replacement engine. Stands to reason that at some point a factory tilt hood might have been replaced with a conventional-type for lack of funds to order a replacement. "Eh... We've got an '82 sitting back here with a blown engine, let's just swap the nose."
Other than the tilt versus conventional variance, they look the same. And then again, it may have just been an option preference that some Ford chassis were shipped with, others not. I'm honestly wondering if it was an air brake versus hydraulic brake thing. Come to think of it, I've seen one with a 370 gasser and air brakes, with a tilt-nose. I'm not quite sure why that would make the difference, (or why a gasser would be ordered with air brakes) but if anyone can confirm that, would be interesting to know.
Old 09-16-2013, 11:53 PM   #18
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I've had all three. Flat front rear engine, flat front front engine and a dog nose. My favorite to drive is my International flat front front engine. I've hauled a LOT of crap with it. That's why I bought it. It's 30 feet long with a 13 1/2 foot wheelbase. It drives like a Honda. It is not as quite as the rear engine. The trans sucks(AT545) but I'm still happy I have it. The 40 foot BBAA rear engine is to long for around town driving and many state and fed parks have length restrictions. Elliot is right about being more difficult to work on.
I'm hungry!
You Gotta Let Me Fly
Old 10-19-2014, 07:28 AM   #19
My mid-80's Ford had a conventional hood. It was all original. It was probably a manufacturer thing like the International front ends on IC buses vs bluebirds back in the early 2000's. My bus was a Thomas.
Roll Your Own Build Thread
Old 10-19-2014, 11:17 AM   #20
lornaschinske's Avatar
Rated Cap: 89
I prefer the looks of the Flat-Nose Blue Bird. Since David got his choice on our first bus, he said I got to choose the second bus (a fact I reminded him that HE said when he decided the Eagle wasn't going to work ). My favourite RV is a pre-1987 Blue Bird Wanderlodge. After 1986, the Wanderlodges started looking like every other RV on the highway. Our All American is a FE. The Eagle had a rear engine and while it was easy to get to, I did not like the single entry point. It is hard to get normal sized appliances in/or the narrow entrance door. With the pusher we HAD to use a emergency hatch/window to escape the rear section of the bus. With a rear emergency door (we kept access to ours), we can, and have, loaded/unloaded all our appliances. For our purposes and use, the front engine is what we prefer. As for the Flat-Nose... that was purely for looks. And I getting too old to be climbing up a ladder to clean the windshield. One size, or one style, does not fit all.
Fulltime since 2006
front vs rear engine? (flat nose) dan-fox Conversion General Discussions 8 12-04-2014 08:52 PM
Mid size Blue Bird flat-nose Das Mel Classifieds | Buy, Sell, Swap 10 05-30-2013 02:53 PM
Flat nose seen on I87 in NY state dgorila1 Skoolie Conversion Projects 0 08-03-2012 10:40 AM
93 Thompson body flat nose wiring fireman Skoolie Conversion Projects 8 04-24-2011 12:49 PM
Engine noise on a flat nose jugganaut Conversion General Discussions 15 10-04-2010 11:05 PM
