Old 08-05-2015, 08:10 PM   #21
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
I just installed a lock on my doors like this and it worked out really well. I won't get back home until tomorrow, but can take some photos then.
It is from a company called atlanticshed.com and is their heavy duty three point locking system.
http://www.atlanticshed.com/2point.htm
Bill
Michigan
miltruckman is offline   Reply With Quote
Old 08-06-2015, 07:59 PM   #22
mikeacg's Avatar
Rated Cap: 12
Sorry for taking so long to get back with pictures... As you can see, I put a slide on my front door that hangs down below the sill and locks with a padlock. I also put padlocks on the other doors but I will replace them once I get it moved over here and start working on the bus. When I put the locks on, I was parking the bus at my mother's house for several months before I moved up here permanently and was just making sure none of my stuff grew legs...
Mike
mikeacg is offline   Reply With Quote
Old 08-06-2015, 08:19 PM   #23
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
That looks like a master lock for which there are only 12 keys. On the other hand, locks only keep honest people honest.
Zephod_beeblebrox2 is offline   Reply With Quote
Old 08-06-2015, 08:46 PM   #24
mikeacg's Avatar
Rated Cap: 12
I know! I can pick a Master Lock in under 60 seconds!
I put this set on recently so I could use my other locks on the outbuildings at my house. There is nothing on the bus now so it is less of an issue. I'll be moving it over here as soon as we get the parking pad leveled and some gravel spread.
Mike
Mike
In Michigan's beautiful UP
Old 08-06-2015, 09:20 PM   #25
Year: 1994
Engine: 466dt
Rated Cap: 59
I wouldn't even bother with the lock. 20 seconds with my angle grinder would see the hasp gone!
Old 08-06-2015, 11:54 PM   #26
Engine: 190hp 5.9 Cummins
Dumb thieves don't carry cordless angle grinders
I would be inside in less than 5 seconds. One smack with a 4 pond hammer and they just pop open.
This is why I use armored Puck Locks.
I use the "Brinks" brand.
$40 with hasp.
Old 08-07-2015, 05:18 AM   #27
Coachwork: IC
Chassis: CE300
Rated Cap: 32
This is the side door lock but its the same kind of lock, keyed the same.
Those locks you have are famous for breaking.
Old 08-07-2015, 09:51 AM   #28
Year: 1994
Engine: 466dt
Rated Cap: 59
Doesn't surprise me. I went to a locksmith with a specific requirement. The locks work but aren't what I wanted and they failed totally to produce a solution for the front door. They call themselves locksmiths but are actually just box shifters in disguise. They might have a locksmith working with them but I doubt it.
Old 08-08-2015, 11:16 PM   #29
Engine: 5.9 cummins
Ill try to attach a photo of the door lock i installed from tge outside. Both my doors swing out. Bluebird tc2000
Bill
Michigan
Old 08-08-2015, 11:19 PM   #30
Engine: 5.9 cummins
Here os a photo of the door lock set from the inside. It puts a rod up through the top of the door frame and down through the step at the bottom.
Bill
Michigan
