Old 08-08-2015, 11:32 PM   #31
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Zephod_beeblebrox2 is offline   Reply With Quote
Old 08-09-2015, 12:23 AM   #32
hi all, I have the split doors too and it was not easy to find something that would lock decently and yet still mount in the limited space between the windows. I ended up using a puck type lock setup. works great for now until I rebuild the door later in to a one piece.
montanatown is offline   Reply With Quote
Old 08-09-2015, 08:05 AM   #33
Chassis: I.H.
I mounted an actuator in the cavity above the door. It pushes the post down. That post blocks the door from opening. It is wired to a controller that uses a key fob to move the post. With a push of a button, the post moves up out of the way and the door is unlocked. A push of the other button and the door is locked. It came with two key fobs and more can be ordered. Nothing is visible once installed.
Check page 5 of my build to see the details.
Old 08-09-2015, 09:05 AM   #34
crazycal's Avatar
Fancy pants.
I'm hungry!
You Gotta Let Me Fly
Old 08-09-2015, 09:10 AM   #35
Year: 1994
Engine: 466dt
Rated Cap: 59
Hmm... Looks like nobody has tried simply to use existing hardware. When I finish painting, I'll crack on with building an unlocking mechanism!. My problem is there's a lock present that needs to be unlocked from outside.
Old 08-09-2015, 12:55 PM   #36
Chassis: I.H.
Originally Posted by crazycal View Post
Fancy pants.
We just had issues that I needed to overcome. We don't want to wait to unlock a door when it is raining out. We wanted a lock that nobody could lock shut from the outside except us. My wife sometimes has to get in to a bathroom without delay. My solution overcomes these.
