Old 04-05-2018, 05:36 PM   #21
bfuller181's Avatar
Chassis: Chevy Express 3500
Rated Cap: 27
Did you disassemble the original door latch arm mechanism on the inside? That was my hope with installing this lock, but I just discovered that the door has too much movement without the original latch.
bfuller181 is offline   Reply With Quote
Old 04-05-2018, 05:50 PM   #22
ACamper's Avatar
Originally Posted by Tootalltechie View Post
That type of lock is easily broken with a pipe.
Link ?
I am having trouble finding it.
ACamper is offline   Reply With Quote
Old 04-05-2018, 05:52 PM   #23
Sasquatters's Avatar
Coachwork: Thomas EF
Locks only keep honest people honest. These buses have 10+ windows on the sides and two giant ones in the front. A bank vault door isn't going to keep people from getting in.
Our Blog | Facebook | Instagram
Sasquatters is offline   Reply With Quote
Old 04-05-2018, 07:03 PM   #24
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Which is why I leave Brunhilde unlocked. Plus, they have to get by my landlord's house.
Old 04-22-2018, 03:39 PM   #25
Originally Posted by newinsl View Post
Prime-Line Products U 10817 Deadlock, Jimmy-Resistant, Single Cylinder Door Lock with a Satin Nickel Finish https://www.amazon.com/dp/B00BAFIUFQ..._yUlWULt8cFzdq
I used one of these and couldn't be happier.
Your install is very nice! Was looking for something like this but only found much more expensive solutions, this is quite affordable!
Just ordered the lock
Thanks!
KasperNL is offline   Reply With Quote
Old 05-09-2018, 03:46 PM   #26
Yukon Cornelius's Avatar
True, But if you don't roll out the carpet for them they will likely move on....
And not to be overly cliché but I lock the door when I we go to bed for other peoples protection.....
Yukon
Yukon Cornelius is offline   Reply With Quote
Old 05-09-2018, 06:51 PM   #27
ComfortEagle's Avatar
Coachwork: Gillig
Chassis: Phantom
Engine: Cat 3208/Allison MT643
Mine's not done yet, but I will be using a conventional house deadbolt and door latch.
Rick <>< - Comfort Eagle (Bird Strike) - Solar/Batteries - Seat - Door - Dash - Mini Split - Fuse Box - Wood Stove
ComfortEagle is offline   Reply With Quote
Old 05-11-2018, 11:55 PM   #28
Rivetboy's Avatar
Thats an old cliche. Have you ever removed a windshield? it is one tough mofo. As for beating in a window that is 6 feet off the ground ?
Not likely The thing that slows down todays low rent with a pair of harbor freight bolt cuttres or a 4 foot piece of pipe or even an angle grinderdefended against with a a small investment of time and money .For example your rear door is openable in a heartbeat with nothing more than a pocket knife.
Try it, put pressure on the door and use a sharp pointed knife to to push the bolt back.
Or, since there is such a generous gap around your unprotected bolt, an 18 inch prybar would pop that door faster than you could open it with the key.
Rivet a spacer in the door jamb so a pry bar will not fit and rivet a plate over the bolt and voila, the thief moves on.
Great instructional video on the installation though.
Rivetboy is offline   Reply With Quote
Old 05-12-2018, 12:45 AM   #29
All the rear windows that are rubber gasket mounted can be breached in seconds, quietly.
Old 10-25-2018, 04:35 PM   #30
scoolbus1's Avatar
Rated Cap: 35 kids
I am installing a surface mount deadbolt with a combination mechanical lock. It is made by Lockey and cost $93-$134 . Get the extension kit that will extend the lock up to 5" for around $17. the surface mount lock does away with the need for a wood panel addition to let a regular deadbolt work. I'll post a video when I get it done...
scoolbus1 is offline   Reply With Quote
