Old 10-25-2018, 04:41 PM   #31
scoolbus1's Avatar
Rated Cap: 35 kids
I have a folding door that folds inward. I drilled a 1/4" hole near the front left corner of the bottom step and when the door is closed from the outside, insert a 4" slide padlock thru the hole and around the metal slide guide located in the same area as the hole you drilled.. this prevents the slide from opening the door. it also saves extensive work installing latches or cylinder locks , on this type of door anyway....
scoolbus1 is offline   Reply With Quote
Old 10-25-2018, 05:01 PM   #32
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
I used these locks - a single cylinder jimmy-proof lock. Turned out nice I think.
Granted it's not on the bi-fold door, but I think it would fit and work well there as well.
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 10-25-2018, 05:34 PM   #33
juliol's Avatar
Engine: 3208 turbo Cat
Scoolbus, like this?
juliol is offline   Reply With Quote
Old 10-31-2018, 10:05 AM   #34
ComfortEagle's Avatar
Coachwork: Gillig
Chassis: Phantom
Engine: Cat 3208/Allison MT643
I recently installed the door locks; more details here
Rick <>< - Comfort Eagle (Bird Strike) - Solar/Batteries - Seat - Door - Dash - Mini Split - Fuse Box - Wood Stove
ComfortEagle is offline   Reply With Quote
Old 02-13-2019, 10:53 AM   #35
Simple temporary lock
I am starting off by using my school bus to move to Florida from Baltimore. I need to lock the bus during loading or when I go to a rest area. Here is my simple temporary solution.
neatpleats is offline   Reply With Quote
Old 02-13-2019, 11:00 AM   #36
school bus door
Here is a video of my lock idea.
Old 08-13-2019, 11:57 AM   #37
Deleted and reposted with solution referenced
MotoSphynx is offline   Reply With Quote
Old 08-13-2019, 12:01 PM   #38
Originally Posted by newinsl View Post
Prime-Line Products U 10817 Deadlock, Jimmy-Resistant, Single Cylinder Door Lock with a Satin Nickel Finish https://www.amazon.com/dp/B00BAFIUFQ..._yUlWULt8cFzdq
I used one of these and couldn't be happier.
Marvelous solution. I believe this will work for mine as well. Thank you ☺
Old 08-13-2019, 01:46 PM   #39
farok's Avatar
Engine: 6.0L Gasser
Has anyone found one of these jimmy-proof deadbolt kits where you can get more than one with a common key? I'm OK with a couple extra keys if I have to, but would like to have a common key for multiple deadbolts if possible.
My build thread: http://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
