Old 11-30-2005, 10:19 PM   #1
Door locks
How do I lock the side door of my bus from the outside is their a mod or kit I can install to make it locking, right now I just lock it and exit the back door and that door needs a lock also, what are you guys doing ?
Its a 87 Chevy C60 bluebird if that matters.
hoser is offline   Reply With Quote
Old 12-01-2005, 12:08 AM   #2
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
My front door is a two piece air operated that opens outward, I've heard them referred to as a 'clamshell' door i think. I put an eyebolt in each half near where they meet in the center (where the door opens) and use a bicycle lock.
My bus is a rear engine, so has no back door (that's practically useable), but on the side door I used a standard house type deadbolt. The door is thinner than a house door, but the distance from the outside face of the door to the inside of the jam is exactly 2-1/4", the door thickness that the lock was made for, so just mounted the deadbolt with a piece of 1x4 under it, made it an exact fit. The lock was 3-1/2" high so no trimming the width of the 1x4 either. Have to cut a 1-1/4" hole through the door to install the outside key part. I didn't install that part, since the bottom of the door is too far off the ground to get into anyways, I just use the front door, but it does look neater on the inside than the long bar and latch that came with the bus.
Oh, you also have to take the lock apart and reverse the bolt, since the door opens out, rather than in as a regular house door.
Seems like you'd be able to use one of these on the front door too, you'd have to cut a slot in the step for the bolt.
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 12-01-2005, 04:58 AM   #3
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Here's what I did on my front door: http://www.skoolie.net/gallery2/T_Handle_Lock,
and examples of what others have done on the rear door: http://www.skoolie.net/gallery2/RoadTrip
http://www.skoolie.net/gallery2/BigG...ly_4_and_5_014
http://www.skoolie.net/gallery2/Kirb...ltModification
and here's a thread you might check out: http://www.skoolie.net/forum/viewtop...ght=front+door
Griff is offline   Reply With Quote
Old 12-01-2005, 04:08 PM   #4
I just put on your basic padlock clasp on the rear door along with a lock on the inside handle (I simply drilled through the handle and the metal band that protects it)..although after looking at mine i think a simple household dead bolt might fit with some work.
Demonknight is offline   Reply With Quote
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
door locks woody Classifieds | Buy, Sell, Swap 2 04-17-2012 07:45 AM
Need about 6 baggage door locks frank-id Everything Else | General Skoolie Discussions 2 04-02-2012 11:04 AM
Door locks? keith Conversion General Discussions 22 03-13-2011 09:41 PM
Little help with locks newbusser Conversion General Discussions 5 10-20-2009 08:30 AM
